Project Muley Crazy 800B
Discussion in 'Canyon Offroad' started by az scout guy, Sep 2, 2010.
  1. az scout guy
    az scout guy Binder Driver
    May 31, 2009
    656
    Apache Junction,AZ
    This project,
    when it came to us it was a 1971 800B, 304, BW11, Dana 30 front and 44 rear. It has custom Alcan lift springs and 33x9.5 BFG All terrain tires.
    The plan is to do a complete body off restoration. Powder coated frame and everything blasted in and out, primed, sealed and painted the original white color. The engine is a built 345 with balanced crank, flat top pistons bored .030 over, mid range cam.4 barrel carb. The transmission will be a built TF727 auto hooked to a Dana 300 T.C. Scout II axles. The Scout is being built with a purpose, the owner is an avid hunter and will be using the Scout for his hunting adventures many miles into the back country.
    The pics are of the first two days in the tear down stage of the restoration. taking apart all the parts and pieces we will be reusing and start to tear apart the front sheet metal, doors, top, hood, cross support for radiator and the the 304 engine.
  2. az scout guy
    May 31, 2009
    656
    Apache Junction,AZ
    Re: Mule Crazy 800B
    some more pics of the Scout in the process of tearing it down
  3. az scout guy
    May 31, 2009
    656
    Apache Junction,AZ
    Re: Mule Crazy 800B
    Some more pics
  4. az scout guy
    May 31, 2009
    656
    Apache Junction,AZ
    Re: Mule Crazy 800B
    more pictures of the Scout getting torn down for the blaster
  5. az scout guy
    May 31, 2009
    656
    Apache Junction,AZ
    Re: Project Mule Crazy 800B
    Took the Scout on the trailer to a local car wash and pressure washed all the nooks and crannies. Getting everything ready to take the body off the frame and then to the media blaster along with the frame. before we take the frame we will weld the new front hangers on for the Scout II axles, no need to do this in the rear because we can cut the perches out to the 800 frame width. the reason we can't just move the front is because of the cast perch on the front 44. Here are some pics of it on the trailer going to the car wash and a few more of the tear down.
  6. az scout guy
    May 31, 2009
    656
    Apache Junction,AZ
    some more pics. Before we take the body off we will also setup the Scout II p.s box on the frame and make the needed modifications to the frame and body, I will post pics of that going together. All the rust spots will be replaced with new metal.
  7. guidolyons
    guidolyons High Wheeler
    Jul 5, 2006
    1,860
    215
    Corpus Christi, TX
    Cool:punk:
    You do nice work AZ Scout Dude:beer:
  8. az scout guy
    May 31, 2009
    656
    Apache Junction,AZ
    Thanks Guido, you do some good work yourself
  9. az scout guy
    May 31, 2009
    656
    Apache Junction,AZ
    Here are some pics of the steering box conversion, we used the plasma cutter to cut the old mount off then put a new mount for the Scout II box.
  10. az scout guy
    May 31, 2009
    656
    Apache Junction,AZ
    a few more of the p.s conversion
  11. az scout guy
    May 31, 2009
    656
    Apache Junction,AZ
    We are also using a plasma to blow out the spot welds on the rear quarters for removal.
  12. mcsmythe
    mcsmythe Farmall Cub
    May 21, 2008
    97
    Mesa, AZ
    looks like the new plasma is working great. probably saved you tons of time on those spot welds.
  13. JOBIE
    JOBIE Farmall Cub
    Dec 31, 2006
    366
    Fort Collins, CO
    Looks good. Cant wait to see the end result, glad someone could take it to the next level. I will miss her though.....
  14. az scout guy
    May 31, 2009
    656
    Apache Junction,AZ
    Here are a few pics of the body getting ready to be removed from the chassis. and a few of the door braces to keep the body from folding in half, this is also a great place to pick up the body from.
  15. az scout guy
    May 31, 2009
    656
    Apache Junction,AZ
    and the body off
  16. az scout guy
    May 31, 2009
    656
    Apache Junction,AZ
    on the trailer ready for the media blaster
  17. az scout guy
    May 31, 2009
    656
    Apache Junction,AZ
    We got the body panels and the tub at the sand blaster and now we are getting the frame ready for blasting and powder coat.
  18. Damian Grihalva
    Damian Grihalva High Wheeler
    2,158
    Colorado Springs
    What suspension plans are you going to do with this one?
  19. az scout guy
    May 31, 2009
    656
    Apache Junction,AZ
    The plans for the suspension is to keep the custom Alcan springs and 5" shackles. The shocks were maxed out when I got it, so some 12" or 10" travel shocks will be in the works. Also i moved the rear shackle hangers forward about an inch to cure the rear shackle inversion. I moved the front axle forward an inch to clear more room for the 33" tires. Built some spring hangers so they slide off rocks instead of off the frame. Very simple suspension on this project, I wish he would call and change to links:yes: I will update this thread with some pics of the frame being prepped for the blaster and powder coater.
  20. JOBIE
    JOBIE Farmall Cub
    Dec 31, 2006
    366
    Fort Collins, CO
    about time for some new updates.....:bananrap::bananrap::bananrap:
