Piston inscription
Discussion in 'General IH Tech' started by oscarthescout, May 23, 2020 at 8:17 PM.
  1. oscarthescout
    oscarthescout Farmall Cub
    Jan 7, 2004
    316
    Eminence MO
    Yes I searched but could not find the answer. I am currently refreshing a 304 that has been on an engine stand in my garage for over 15 years. It is out of a 79 scout ii. I am trying to determine if the pistons are stock sized. The inscription on the top say z23 319131-c2. Is this a standard bore piston? To my knowledge this engine has never been rebuilt. Still had the original ih steel style head gaskets already purchased some stock rings but I want to be sure
  2. rwk
    rwk Farmall Cub
    Jan 29, 2012
    26
    battle creek mi
    Best to measure them to know for sure. Measure bore if they are still installed.
  3. jeff campbell
    15,221
    1,446
    If stock it will have " std" under #. If oversized it will/should be stamped. Post up a pic of piston.
  4. jeff campbell
    15,221
    1,446
    Does not appear to be a good #. Looked in my 3 books. Z23 ? Z= zollner i believe.? Not sure.
  5. jeff campbell
    15,221
    1,446
    1 quick way to find out is place a ring in cylinder. See if you have a gap or not. I file fit my to have a .020 gap.
  6. oscarthescout
    Jan 7, 2004
    316
    Eminence MO
    Here is a picture
  7. Dana Strong
    5,530
    1,345
    You left out a 9 on that number; it should be 391931-C2:
    Even so, neither of my two scout books list it.
  8. jeff campbell
    15,221
    1,446
    I just found a set on ebay # 391 931 C2, with rod # 216 113 R1.... This set was out of a 71- scout 800a 304. Standard bore. CANNOT find # in any of my parts books.
  9. oscarthescout
    Jan 7, 2004
    316
    Eminence MO
    Thanks standard bore. I am good to go. I used to spend a lot of time on here 10-15 years ago back when it was the other forum. I gained so much scout knowledge from here. It's great to see it is still active and the familiar experts are still helping folks out. Thanks Jeff
  10. jeff campbell
    15,221
    1,446
    Your very welcome. The old binder bulletin. Bill thebeit
  11. oscarthescout
    Jan 7, 2004
    316
    Eminence MO
    I
    Is Bill still around didn't he have a lifted red scout with red ssii door inserts? I used to have that scout as my computer wall paper
  12. jeff campbell
    15,221
    1,446
    Not here. On FB...ive seen his comments.
  13. Howard Pletcher
    Howard Pletcher Farmall Cub
    Jul 23, 2007
    278
    101
    Fort Wayne, IN
    Service Parts part numbers were often different than production numbers because of they way they were purchased even though the part may not be different.
  14. jeff campbell
    15,221
    1,446
  15. Dana Strong
    5,530
    1,345
    Yes, and that is sometimes noted in the Parts Books.
    Jeff, out of curiosity I searched for that (both on Ebay, even under Sold items; and on the internet) but didn't find it. Could you provide the link to what you found?
  16. oscarthescout
    Jan 7, 2004
    316
    Eminence MO
    So I did this check today just to be sure. rings almost touch end to end when placed in the cylinder. I did not check with my feeler gauge but the cylinders are definitely not over bored.
