Only get spark when turning switch off
Discussion in 'General IH Tech' started by Randall Barringer, Oct 28, 2019.
  1. Randall Barringer
    Mar 4, 2004
    3,721
    854
    baton rouge, louisiana
    I am working on getting the military Scout running and I´m having an issue.
    I only have spark from the coil when I turn the ignition switch off.
    No spark while cranking.
    I haven´t looked into the wiring other than cleaning the connection at at the ballast resistor.
    Where should I begin?
    Thanks
  2. walkersscout
    walkersscout High Wheeler
    Oct 5, 2005
    1,610
    273
    AZ
    Do you have a wire from the coil to the starter solenoid?
  3. Randall Barringer
    Mar 4, 2004
    3,721
    854
    I'll confirm, but I'm pretty sure it's there.
    Thanks
    Sent from my SM-G955U using Tapatalk
  4. RinTX
    2,469
    876
    I guess I’d start at the switch? Wires connected to wrong positions at the switch?
  5. Jeff Jamison
    7,826
    1,173
    Solenoid on the starter has a contact that sends power to the coil while cranking/ingaging starter,This is the R terminal on the starter,check there for power,if not clean contactor/replace solenoid .If power there check wire to coil/coil side of the ballast resistor .
  6. Randall Barringer
    Mar 4, 2004
    3,721
    854
    Thanks, everyone. This gives me good places to start.
  7. Bob BMW
    Bob BMW Binder Driver
    Feb 12, 2015
    543
    179
    Colorado Springs, CO
    As long as we are guessing, my guess is points stuck together or the wire from the points side of your coil to the points in your distributor is shorted to ground somewhere.
    You are getting power to the coil with the switch on. When you turn the switch to off you get a spark. This happens because one side of the coil is grounded and you remove power from the other side. Kind of sorta the opposite situation of normal operation.
    Good luck.
    Bob
    Randall Barringer likes this.
  8. scoutboy74
    6,712
    1,160
    The starter solenoid 'S' terminal does not feed the coil. That terminal receives power from the ignition switch when turned to the Start position, which then causes the starter motor to engage. It has nothing to do with coil function. The solenoid 'R' terminal on the other hand, is a resistor bypass feed to the coil, which does momentarily supply full battery voltage to the coil only while the starter is cranking. The primary power feed to the coil is supplied from the ignition switch and it should be energized in both key switch ON and Start positions. You can rig a temporary jumper directly from the battery POS to the coil which will bypass the switched feed to the coil. Just don't leave that jumper connected with the engine stopped, and don't run the engine for too long on that jumper either. The coil is also not connected to chassis ground. The negative coil terminal is connected to the breaker points inside the distributor.
  9. Jeff Jamison
    7,826
    1,173
    OOPs I meant R,will go back and fix.
  10. Randall Barringer
    Mar 4, 2004
    3,721
    854
    This was the issue.
    It's not running yet, but I have spark when I crank it.
    Thanks
    RinTX and Bob BMW like this.
  11. Bob BMW
    Feb 12, 2015
    543
    179
    Very good Randall. One step at a time and you will get there.
    Thanks for reporting back too.
    Bob
  12. Randall Barringer
    Mar 4, 2004
    3,721
    854
    That middle wire was screwed down with the others.
    I'm not sure where it belongs. These delco distributors are tough to analyze because you can't see anything. When I removed it I got spark while cranking. I'll dig deeper tomorrow. [​IMG]
    Bob BMW likes this.
  13. Bob BMW
    Feb 12, 2015
    543
    179
    That middle wire that was screwed down with the other two screwed you. The other two wires are: One is from the points terminal on your coil and the other one is from the condenser which is located inside your distributor. That third wire is a ground wire. Since it was connected to the other two, it was grounding your coil, which I suggested in my first reply, was causing your odd symptom.
    It has been many many years since I messed with a distributor of this type on my Scout. My manual doesn't show a very good picture of where the ground wire connects but I believe, from looking at your picture and my service manual, it goes under the points mounting screw that you can see under the black 'third' wire. Remove the screw and internal star lock washer and then clamp the wire to the breaker points plate with the screw and it's lock washer. The other end of this ground wire is clamped down with one of the vacuum advance canister mounting screws.
    Bob
