Nylon tubing
Discussion in 'General IH Tech' started by Sammy, May 17, 2019.
  1. Sammy
    Sammy Y-Block King
    Oct 22, 2001
    3,040
    399
    Grigsby's Bluff, TX
    I have the nylon fuel line from previous scouts that I'm using on the one I have now. I think they came off of the diesel scouts. One is black and the other is white and I don't think it matters but which one is the feed and which one would be the return.
  2. stevewillis
    stevewillis Farmall Cub
    Jul 24, 2006
    322
    89
    Flagstaff, AZ
    I can’t speak to diesel, but gasoline Scouts did not have a return fuel line. A return line is usually added with a fuel injection conversion. Mine was light yellow.
    Correction: my vapor line to the charcoal canister was yellow nylon. I think my fuel feed line was just standard rubber hose.
  3. winchested
    3,017
    1,061
    Stock, black is the feed 5/16 tube and the white goes to the charcoal canister.
  4. winchested
    3,017
    1,061
    If you're going EFI upgrade to 3/8" feed and 5/16 return.
    MrKenmore likes this.
  5. Sammy
    Sammy Y-Block King
    Oct 22, 2001
    3,040
    399
    Grigsby's Bluff, TX
    Should have looked before I posted this morning. I found out the above when I checked the other turd that's back there.
