Noise catch in front axle drivers side only
Discussion in 'General IH Tech' started by UplandHunter, Aug 27, 2020.
  1. UplandHunter
    UplandHunter Farmall Cub
    Oct 2, 2009
    199
    56
    Kinston, NC
  2. jeff campbell
    15,811
    1,713
    Id pull front cover for a visual inspection to start with.
    UplandHunter likes this.
  3. scoutboy74
    6,729
    1,165
    They were using it as an aftermarket manual choke. Inspect your lockout hub, inspect your wheel bearings and pull your stub axle shaft. Be prepared to replace bearings and seals while you're in there.
  4. INT77345
    INT77345 Farmall Cub
    Feb 3, 2009
    316
    49
    DENVER
    with the hub disengaged spin the wheel and look at the axle shaft u joint. when it makes the noise and if your axle shaft is not spinning with the wheel then i dont think your noise is in your diff. because nothing would be moving with out the shaft moving.
    i think the noise is something catching in that hub.
  5. BigRigg
    BigRigg Y-Block King
    Mar 12, 2004
    3,294
    659
    West Fork, AR
    I would also start with the hub. Work your way in from there.
  6. UplandHunter
    Oct 2, 2009
    199
    56
    Kinston, NC
    Working through the noise - it’s coming from the hub. If I am going to pull it, I guess rebuilding it should be part of the plan. It’s a rusty crusty one so probably needs it.
  7. INT77345
    Feb 3, 2009
    316
    49
    DENVER
    do you want to stick with that style of locking hub ? if so that is fine. if not there are options out there. iv run warn hubs for the last 25 years.
