New to the scouts
Discussion in 'Better Scout Parts' started by Jason kirby, Jul 22, 2018.
  1. Jason kirby
    Jason kirby Farmall Cub
    Jul 22, 2018
    Hi I just recently picked up a 1967 scout that was insanely built and appeared in magazines but has since seen better days being new to scouts I had a few questions was hoping to get some education on.
    1 why does it have 3 shifters
    2 my motor is a 4cyl which seems small for the size axles and tires but It has 5:38 gears are there better motors for the scout
    3 where can I find body parts for it and how do I get the rear body panels off the ones where the tail lights are
  2. winchested
    winchested High Wheeler
    2,907
    995
    There are no steel replacements for the rear end caps for the 80s/800s. Fiberglass is avail. As far is I know.
    67-71 800s were avail with a 266 or 304 I believe for V8 power. But modification to the core support has to be done I believe.
    5.38s are likely fine what size are the tires.
    It has 3 shifters because 1 is your gear shift.
    2 is hi range shift and 3 is low range shift.
    Google twin stick transfer cases and you will get it.
    Ps.
    This thread is useless without pictures!
    Chucktshoes likes this.
  3. Packerrailway
    Packerrailway High Wheeler
    Mar 25, 2015
    2,307
    2,024
    Lodi, WI
    4 banger is most likely a 196. 3 sticks = transmission closest to driver; center = front axle. Forwards is out, rearwards is engaged; right = Hi and Low, forwards is low. DO NOT run in low rear wheel only! Should be Dana 20 transfer case, if not changed out.
  4. Jeff Jamison
    7,231
    841
    It would be better to post this in the general IH tech up higher on the page.This is a vendor (parts dealer) area on this site.
  5. Jason kirby
    Jul 22, 2018
    Here is a couple of pics the current tires are 38x14.5x16.5
    And I know the rear axle is a Dana 60 and front is a Dana 44 both have lockers and 5:38 gears
    And the scout tops at like 45 to 50 mph
