NEW PRODUCT ~ RockerSliders
Discussion in 'D and C Extreme' started by Damian Grihalva, Nov 5, 2007.
  1. Damian Grihalva
    Damian Grihalva High Wheeler
    2,158
    Colorado Springs
    Well you guys have seen my little invention on the Evo project, and since they're appearance on EVO, I've gotten a few inquiries about them. So I've decided to offer them as a special order item.
    The dimensions are 3.5 x 3.5, the front and side will be angled as seen (45* angle).
    The new RockerSliders are basically Extreme-Duty replacement Rockers. They come welded up as seen and completely enclosed. Custom lengths available. $450 per pair.
  2. Ki Areese
    Ki Areese Binder Driver
    Jul 13, 2006
    765
    massachusetts
    These look pretty sweet, any pictures on a finished truck? I might be in the market, depending how bad the rust is on my new scout.. I'll let you know when its delivered
  3. Damian Grihalva
    2,158
    Colorado Springs
  4. turbogreaser
    turbogreaser Farmall Cub
    Nov 13, 2007
    66
    Minnesota
    Hey D-
    Using these more as replacements to rustproof vs sliders. Doors should shut just fine as long as welded flush, correct? (assuming wheatherstripping etc.).
    Thanks,
    Eric
  5. StanMcMurrey
    StanMcMurrey Farmall Cub
    Nov 29, 2002
    230
    Houston, TX
    Those are nice, in your opinion are they strong enough without tieing them into the frame? Sliders will take some hard hits and is this going to screw with the body alignment after some abuse? Would a few bushings with frame tieins be worth it?
  6. Damian Grihalva
    2,158
    Colorado Springs
    Correct, the door should shut fine if installed correctly.
    Yes ~ but if you're going to do some heavy wheeling with frequent and hard hits, then tieing to the frame helps allot. Remember these will spread out the hit over the entire rocker, so you're not just hitting one spot, you're lifting the side of the Scout!:2guns:
  7. jhnyct
    jhnyct High Wheeler
    Aug 22, 2002
    1,831
    Clermont, GA
    And remember, until you tie these into the frame, your rocker/sliders are only as strong as your thirty year old body mounts.
  8. Damian Grihalva
    2,158
    Colorado Springs
    Not sure why one would replace the rockers and not make sure the body mounts are up to snuff ~ but you're right!
  9. bmacguyver
    bmacguyver High Wheeler
    Jul 13, 2002
    1,496
    Devine, Tx
    how much are the rock sliders?
    mac
  10. Fred Demmon
    Fred Demmon Y-Block King
    Jul 26, 2006
    3,706
    66
    Pearland TX
    this is what was said earlier
  11. Damian Grihalva
    2,158
    Colorado Springs
    I have a set of these ready to go! PM me or call.
    Thanks
    D
