New owner of a 69 1200
Discussion in 'The Truck Stop' started by Kens69, Feb 12, 2019.
  1. Kens69
    Kens69 Farmall Cub
    Feb 12, 2019
    Hello all. A new guy here. I just recently purchased a 69 1200 with a manual trans, 4x4, and a plow. It runs, just doesn't stop. ... Body is complete with every type of ventilation holes you could imagine.... Haha. It is gas the split style rims on it, and I am wondering two major things, one, can a guy get different rims? And what can a guy get for brakes?
  2. Jeff Jamison
    7,561
    1,029
    first welcome,second you will get more answers by posting in the general ih tech,up closer to the top.On a 1210 most ford 16" 8 bolt wheels upinto the early 90s will work,on the brakes you can get everything new except the drums
    Kens69 likes this.
  3. Kens69
    Kens69 Farmall Cub
    Feb 12, 2019
    Thank you. Is there any way a mod could move this please?
  4. Kens69
    Kens69 Farmall Cub
    Feb 12, 2019
    She's a little rough... Lol
  5. Kens69
    Kens69 Farmall Cub
    Feb 12, 2019
    Anyone have some insight in what model engine? Has two barrel carb. Didn't find an I'd tag.
  6. bindermike
    bindermike Farmall Cub
    Apr 6, 2003
    253
    Lorton, VA
    Ken, the engine model number should be stamped into a flat spot on the front passenger side of the block, just below the head. Probably a 304 or 345. Outside chance it's a 392. It might be hidden under layers of "rust preventative"
    Good luck, Mike
  7. Chris Cooper
    Chris Cooper Binder Driver
    Mar 11, 2018
    713
    267
    Longmont, CO
    You should be able to see it through the passenger-side fender well.
  8. Kens69
    Kens69 Farmall Cub
    Feb 12, 2019
    By that you mean the rust collectors haha. There are only the outside skins left
  9. Chris Cooper
    Mar 11, 2018
    713
    267
    Longmont, CO
    If you mean the inner fender is gone, then that engine number should be really easy to spot.
    Mine came from Arkansas, hopefully it's got most of the rusting out of its system here in the (usually) arid west.
  10. Kens69
    Kens69 Farmall Cub
    Feb 12, 2019
    Found out it's a 304 with a Holley two barrel on it. The carb is leaking fuel around the bowl somewhere. I'm thinking the bowl gasket. If I fix that and the brakes, I'll be a happy man. Someone has gooped some silicone on the bowl...
