New Direct Bolt-In Alternator
Discussion in 'Anything Scout' started by scoutrallye, Nov 2, 2012.
  1. scoutrallye
    scoutrallye Farmall Cub
    Jan 28, 2006
    san jose
    This new CS130 direct bolt-in alternator is a great upgrade for your truck. Stock alternators put out 50-60 amps. A must-have for any truck with additional power needs such as stereo, offroad lights, winch, etc. This alternator comes with a direct plug-in adapter (not pictured).
  2. rolinslow
    rolinslow Farmall Cub
    Jan 28, 2012
    106
    liberty hill tx
    Will it fit the diesels too?
  3. Carl Wiese
    Nov 14, 2001
    8,169
    51
    Oregon City, OR
    Diesel scout? No completely different on the diesels.
  4. rolinslow
    Jan 28, 2012
    106
    liberty hill tx
    I figured but i had to ask.
  5. scoutrallye
    Jan 28, 2006
    san jose
    We are actually making a bracket so you could retro fit this alternator in your diesel! The main issue is you would be losing you source of vacuum for your brakes. If you do a hydroboost kit you would be good to go!
    -sean
  6. rolinslow
    Jan 28, 2012
    106
    liberty hill tx
    That would be awsome, i can use an electric vacume pump for a while, let us diesel guys know when its ready. Thx
  7. Devin
    Devin Farmall Cub
    Jun 11, 2002
    202
    Yuma, AZ
    rolinslow, I purchased a CS-130 alternator just the other day (before Sean posted this one and threw in a wiring pigtail, which I still need) intending to make this conversion. I made a conversion similar to this with a 12SI years ago in another diesel Scout and will post a thread, regarding this conversion too. Hopefully, if Sean can build me the alternator bracket to go with I'd be able to post the full Alternator/Hydroboost conversion for a diesel Scout using 'bolt-in' parts contrasted against a few other options.
    I still haven't managed to find a solution for my (now-broken) Hitachi alternator that is allegedly boosted to 70 amps. But that has to do with the scarcity of suitable wiring available to me to replace the alternator's stator wire to pigtail. Once I have that problem solved and can confirm that its output was increased, I'll open it up to find out what was done to boost its output. After the conversion to the CS130, I'll likely put the boosted Hitachi up for sale once I confirm the CS130 is working as desired.
  8. BO185
    BO185 Y-Block King
    Jun 8, 2004
    3,452
    193
    Jacksonville, Arkansas
    Does the alt come with a large gauge shunt wire from alt to battery to bypass the amp gauge and not cause a fire due to overloading the gauge?
    If not it would be advisable to place a note stating that you need to have shunt to prevent damage to the amp gauge/wiring from a liability stand point. I would be mad if I bought one bolted in and it burn my truck up.
  9. Devin
    Devin Farmall Cub
    Jun 11, 2002
    202
    Yuma, AZ
    While I don't imagine the Alternator comes with it, I do know that I plan on covering that mod on the diesel forum when I complete it, and I think I did cover it for the 12SI mod that I did a few years ago (also on a diesel).
    Frankly, I think a person needs to do more than just run a shunt in the engine compartment. But more on that in another thread. BO185 is right in that if you aren't comfortable with learning more about the modifications you're willing to make, then you maybe shouldn't be doing them.
