Need to find oil line for alt/vac pump near Denver
Discussion in 'Diesel Tech' started by PrintSmith, Sep 2, 2009.
  1. PrintSmith
    PrintSmith Farmall Cub
    Sep 7, 2006
    69
    Bailey, CO
    Any one know where I can find the oil line that runs from the block to the back of the vacuum pump/alternator on the stock set-up? I tried to have one made and got standard instead of metric fittings. If anyone has replaced their OE setup and has a hose lying around, I'll buy it from you!
  2. David Dixon
    David Dixon High Wheeler
    Nov 19, 2003
    1,028
    Bath, Maine
    Sent you an email. Have several.
  3. Jim
    Jim High Wheeler
    Oct 17, 2001
    1,189
    34
    Oregon
    Im ready for one of these. Hey David do you still have several? PM Sent.
    I could swear I saw a thread where someone came up with a way to plumb a line from the block to the back of the hitachi alternator (oil line for vacuum pump).
    I have two SD33T's and one has a leaky hose, the other is good. Looking for another hose that doesnt leak or some parts list to make a new one.
  4. jeff campbell
    12,027
    297
    will look, think i've got 1 ?
  5. jeff campbell
    12,027
    297
    sorry jim, don't have 1! i have 2 alt's and neither 1 has 1. i thot they did, just the vaccum fitting & tube.
  6. Joe S
    Joe S Farmall Cub
    Oct 27, 2011
    159
    Sunland, Lompoc, CA
    I should have an unused one from my motor. Since I'm going with hydro-boost for the brakes and Vintage Air for A/C on my project I don't think I'll need vacuum anymore.
    Lemme know if no one else comes through.
  7. mjolnir
    mjolnir Farmall Cub
    Mar 23, 2003
    476
    central Wa.
    BTW the threads for those fittings are BSPT. Easier to find a BSPT to AN adapter fitting. I have a NEB hose but I'll be darn if I know where it is. If your really in a jam let me know and I'll devote some time looking for it.
  8. Jim
    Jim High Wheeler
    Oct 17, 2001
    1,189
    34
    Oregon
    I thought I had seen a thread where someone made a replacement and listed the parts. So far I cant find that thread.
  9. Seanaldo
    Seanaldo Farmall Cub
    Feb 14, 2014
    114
    Tucson, AZ
  10. Jim
    Jim High Wheeler
    Oct 17, 2001
    1,189
    34
    Oregon
    I was able to get a couple of used ones. Thanks for finding the thread. I thought I had seen someone make one.
  11. Joe S
    Joe S Farmall Cub
    Oct 27, 2011
    159
    Sunland, Lompoc, CA
    Couldn't one just replace the hose using the old fittings? If the ferules are integral with the fittings a little work on a lathe or even a grinder should make room for replacements???
