Need tire size equivalent
Discussion in 'General IH Tech' started by rleeds, Jan 20, 2011.
  1. rleeds
    rleeds Farmall Cub
    Oct 7, 2003
    280
    Omaha, NE
    I'm looking for all terrain tires that are 32"x11.5"x16".
    I've read on TireRack.com how to convert, but am, oh, I don't know, confused...:cornfused:
    Can anybody tell me the metric equivalent? I really like the looks of this size. I currently have junked 32x11.5x15 tires and 15" rusty wagon wheels. Got a great deal on some new 16" wheels that'll fit my rear discs and now need to put some meat on them.
    I've seen some mudders & swampers that are advertised as 32x11.5x16, but I want a street, all terrain tire.
    Thanks!
  2. crnbndr123
    crnbndr123 Farmall Cub
    Dec 20, 2006
    442
    Taylor-Snowflake, AZ
    285 75 16 (I think...) Should be about 32 inches tall and just over 11 wide.
  3. ScoutFam
    ScoutFam Farmall Cub
    Mar 2, 2008
    495
    Colorado Springs, Co
    I have 265 75 16 on my f150 and they are real close to if not a little bigger than 32s they are almost as tall as my 33s on the scout
  4. Doc Stewart
    49
    235 85 R16 on my service truck are 31" high.
  5. JordanAMC
    JordanAMC Binder Driver
    Mar 31, 2010
    735
    17
    Carrboro, NC
    Those are more of a 33-34" in most cases.
    265/75r16 are right at 32", if not above. That's the size you want. We run those on our Grand Cherokee.
  6. Patrick Morris
    5,835
    774
    I'm sure you meant 265/75. According to TireRack these usually run just a hair under 32" tall. By 10.5" wide though.
    I agree with you though. It's probably the size to use. I'd get these myself it I had some 16" rims laying around.
    BTW lreeds, there is no need to do any fancy calculating here. TireRack lists all the sizes under the "specs" for each tire band and type. Just pick a tire you like, for instance BFG AT or General Grabber AT2, and look at the specs (it's a tab on the page). You first look in the Overall Diameter column, then Section Width... and then just pan over to the left to see what size it is. Obviously you'd just be looking at the 16" tires there.
    For example, click the Spec tab on this page:
    http://www.tirerack.com/tires/tires.jsp?tireMake=General&tireModel=Grabber+AT+2
