need help on firing order for scout 2 with 345
Discussion in 'General IH Tech' started by Davidmyers, Jun 5, 2004.
  1. Davidmyers
    Davidmyers Farmall Cub
    Jun 5, 2004
    Tarboro
    I need help on the firing order I was tuning my scout in i guess i misplaced one of the wires now i need to get it right again any help would be helpful i know the order im not sure on how the cyl numbers are though
  2. Eric Underriner
    Eric Underriner Binder Driver
    Apr 15, 2004
    659
    New York, NY
    The order is cast into the intake manifold. Scrap off the mud and find it.
  3. Nevada S.
    Nevada S. Farmall Cub
    May 17, 2004
    55
    Winslow, AZ
    According to the International Service Manual, firing order for a 345 is: 1-8-4-3-6-5-7-2 (my manual is Scout II XLC series 1975 thru 1977). Hope this helps. :)
  4. VegasJud
    VegasJud Farmall Cub
    Nov 29, 2002
    155
    Chandler, AZ
    The firing order is cast into the manifold just behind the T-stat housing (kinda keeps it handy for us). Don't forget to time the engine off #8 cylinder.
  5. Munchies
    Munchies High Wheeler
    Oct 19, 2003
    1,462
    Heidelberg, Germany
    Nevada it starts with 8 doesn't it? I forgot scout's too far away to go look.
  6. Munchies
    Oct 19, 2003
    1,462
    Heidelberg, Germany
    Im sorry nevada, I was incorrect, I just looked 1-8-4-3-6-5-7-2 indeed.
  7. Doug Shailor
    Doug Shailor Guest
    Cylinder numbering on IH SV (266,304,345,392) V-8's...
    The left side front to back is 1,3,5,7. The right side front to back is 2,4,6,8.
  8. Dick S. Moore
    Dick S. Moore Farmall Cub
    Nov 17, 2001
    399
    1808 Newton Rd. Corydon IA
    Here`s a good one to Keep
    bravemen likes this.
  9. Doug Shailor
    Doug Shailor Guest
    Excellent!
    Thank you, Dick. I did just that.
    Doug
  10. James Ruth
    James Ruth Farmall Cub
    Dec 16, 2016
    North Carolina
    Thank you! I am new to the Scout II, coming from British TR-6 land. Thus forum is fantastic and the folks are awesome!
  11. mallen
    mallen High Wheeler
    1,269
    51
    Remember that the wire labled 19 MUST go behind the carb to keep it away from its neighbor. There was an IH service bulletin on it. Supposedly it crossfire's with another cylinder and can cause engine damage if you don't route it like that.
  12. James Ruth
    Dec 16, 2016
    North Carolina
    Thanks I appreciate the good advice. I will follow the wiring diagram to a T!!!
  13. scoutboy74
    4,708
    172
    In the SV8 firing order, cylinders 5 and 7 are the only adjacent cylinders that fire in succession. Hence the routing of the cylinder 7 plug wire behind the carb to keep it separated from the cylinder 5 plug wire. Plug wire composition has improved considerably over the last 45 years. So is this wire segregation necessary with modern, high quality plug wires? Probably not, but if you have enough length in your #7, you might as well do it as a just in case.
  14. mallen
    mallen High Wheeler
    1,269
    51
    I thought about that when I cut my custom wire set, but then I thought, how many times has somebody thought they knew better than the manufacturer, and ended up really screwed something up. Sometimes you have no choice, ,sayfor example,an original part is not available. Sometimes it's a an upgrade that has massive benefits, like fuel injection or electronic ignition. But why change it up just to avoid routing a wire behind the carb. You probably don't need to ,but if your wrong....
  15. 1975IH200
    1975IH200 High Wheeler
    2,163
    61
    Trevor is correct in that the new plug wires of recent manufacture should not have this 'crossfire' issue.
    If you are still concerned, then you can run the 5-7 wires in parallel, then cross them just before the spark plugs.
