Name This Part! vesion 5.0
Discussion in 'General IH Tech' started by Albuq. Henry, Sep 3, 2011.
  1. Albuq. Henry
    Albuq. Henry Binder Driver
    Aug 27, 2007
    902
    Albuquerque, NM
    Its a 70 scout with a 304.
    Vac in connected on one side. other is loose. It is inline with the speedo cable.
  2. Carl Wiese
    Nov 14, 2001
    8,169
    50
    Oregon City, OR
    Remnants from a cruise control setup.
  3. TRAVELETTE
    TRAVELETTE Farmall Cub
    Sep 12, 2003
    457
    75
    WI RAPIDS,WI
    Valve,road speed sensor.
    IH part number 396346C92 unless California emissions.
    IH part number 413306C91 with California emissions.
  4. Albuq. Henry
    Aug 27, 2007
    902
    Albuquerque, NM
    OOPs.... thass a big part. lol
  5. Dennis Bernth
    5,968
    41
    Mill Creek, IN.
    I've seen that before on 800's, I think it's a doomajig to vary the vacuum to your windshield wipers depending on speed. I don't see the wires that a cruise control should have....call it a vacuum regulator for the wipers.
  6. Albuq. Henry
    Aug 27, 2007
    902
    Albuquerque, NM
    Cool thanks guys. I was thinking that but there is nothing in the cab or on the carb.
  7. Jeff Jamison
    7,568
    1,033
    What it did is when you let off of the gas,the vacume held the carb slightly open instead of slaming closed something about burning off gas,emitions type thing
    Jeff
  8. Albuq. Henry
    Aug 27, 2007
    902
    Albuquerque, NM
    ok there is a dashpot on the carb...
  9. Afireinside2285
    Afireinside2285 High Wheeler
    Nov 2, 2003
    1,732
    25
    colorado
    There are a few threads on this and it seems that the common consensus is that it chnges the timing in a decel mode.I'm not sure,I have had it on 3 IH's and it's stamped holley,but none of my carbs had a dashpot.
    I usually just remove it and put a one piece speedo cable in and remove the vacume lines.
    BTW I have never seen this past 1972. maybe 69-72.
    Good luck!!
  10. Eric VanBuren
    May 7, 2004
    6,011
    26
    Maple Valley , Wa
    It is the road speed controlled timing device it bleeds off the vac advance to control NOx. Later versions are electric and control a solenoid. Their operation is fully documented in your FSM.
