My 72/73 Scout Rebuild
Discussion in 'Binder Builds' started by Daniel Nance, Feb 1, 2018.
  1. Daniel Nance
    Daniel Nance Farmall Cub
    Dec 27, 2017
    163
    27
    22050353_10100612362158564_2632699309664215501_n[1].jpg 23621952_10100638896583364_603770163627536210_n[1].jpg
    Here are my 72 and 73 scout II's that Ill be combining into one. Ive been at it for months, but am finally posting pics.
  2. Daniel Nance
    Dec 27, 2017
    163
    27
    engine and axles pulled and disc brakes added...
    22789136_10100627023946224_5789008468743292888_n[1].jpg 24293880_10100646214717764_8001325371958535560_n[1].jpg 23722344_10100638896648234_1332643643806991230_n[1].jpg
    Jesse wilkins and fourpoint9 like this.
  3. Daniel Nance
    Dec 27, 2017
    163
    27
    Restoration of loose ends...
  4. Daniel Nance
    Dec 27, 2017
    163
    27
    Transmission rebuilt and headers back from shop...
    26230384_10100663961712644_7477915065950822023_n[1].jpg 23905466_10100642958248754_6053223861059257027_n[1].jpg
    mlc8761 likes this.
  5. Daniel Nance
    Dec 27, 2017
    163
    27
    Frame cleaned and POR-15'd, bumper painted, 33 gal gas tank installed, along with axle and shocks...
    26814928_10100671982823274_2924252395346883687_n[1].jpg 26805331_10100671982853214_9078930430260288646_n[1].jpg 27066821_10100677771353014_5478707241997297906_n[1].jpg 27654439_10100677771308104_8878738424490653373_n[1].jpg
    mlc8761 likes this.
  6. Daniel Nance
    Dec 27, 2017
    163
    27
  7. Daniel Nance
    Dec 27, 2017
    163
    27
    About to move engine to frame and prep for first startup.
  8. 1975IH200
    1975IH200 Y-Block King
    3,151
    469
    Looks really good.
    Don't forget to pull the lower freeze plug on each head before installing the water pipes!
    Daniel Nance likes this.
  9. Daniel Nance
    Dec 27, 2017
    163
    27
    Thanks! I noticed that when I put my heads on.... took forever to find 1 3/8 freeze plug in the county i live in. Some threads I read said they were 1 5/8 plugs, but they are not... live and learn. I finally have the correct size and will install this week.
  10. Daniel Nance
    Dec 27, 2017
    163
    27
    Here are pics of the engine mounted with rebuilt transmission added. Lots more to do.
    Darrel likes this.
  11. 72Blue
    72Blue Farmall Cub
    Feb 27, 2018
    You have put in alot of work. Looks great
  12. Daniel Nance
    Dec 27, 2017
    163
    27
    IMG_8678.jpg IMG_8404.jpg IMG_8703.jpg IMG_8751.jpg IMG_8752.jpg IMG_8680.jpg
    Body work...coating underside of tub with POR-15, and inside panels. First attempt of bondo, sanding, priming on my windshield frame. Also, first time using fiberglass to repair hole in floor.
  13. Daniel Nance
    Dec 27, 2017
    163
    27
    Installed radiator, fuel lines, transmission lines, trans. cooler, TBI harness (I have some sensor questions Ill post in another thread)
    fourpoint9 likes this.
  14. MrKenmore
    MrKenmore Y-Block King
    3,418
    1,173
    Looking good! You're a true shade tree mechanic based on the pics (lots of trees and shade)! Whats the blue-green engine color choice?
  15. Daniel Nance
    Dec 27, 2017
    163
    27
    Thanks! My wife isn’t happy about our backyard looking like a junkyard, but it’s only temporary. I’m going with a light sea foam green color with matte black trim for my finish... that was the closest color engine paint I could fine. We shall see how it turns out.
  16. Daniel Nance
    Dec 27, 2017
    163
    27
    Rewired the scout last weekend using an American Autowire Power Plus 13 Kit from Summit ($250ish). It was time consuming, as I soldered each connection. I still have to connect lights and a few other loose ends.
  17. Daniel Nance
    Dec 27, 2017
    163
    27
    Most deceiving picture Ive posted... this truck bed was grueling work. Had to use a grinder to grind every inch of the bed....bondo from previous owner and rust. I coated with POR-15. Will probably do a wood overlay over the bed. IMG_8878.jpg IMG_8877.jpg IMG_8874.jpg
  18. Daniel Nance
    Dec 27, 2017
    163
    27
    In addition to the bed, I also worked on the front grill - painting inside of grill with POR-15 and primed the front. I finished wiring the headlight fixtures and tested them. I dont have pictures of the steering coupling, but I replaced it. Next up: new speedometer cable + I have to determine where the speedo input is - looks like a plug on the transmission meaning the input will be on the transfer case. Any opinions on location of speedo input?
  19. winchested
    3,239
    1,188
    Yes speedo is on the xfer case!
  20. Daniel Nance
    Dec 27, 2017
    163
    27
    I revamped my gauges with new white faceplate stickers and I cut lexan to fit where the glass was.
    Next I installed reman brake power booster and new master cylinder and proportioning valve for the 4 new disc brakes.
    Also, new throttle and kickdown linkage on the TBI.
    Im almost ready to drive it. I have to bleed the brakes and then add the drive shaft and Im ready to take the scout for the first trip around the block.
