Mr. Scout lift springs before and after
Discussion in 'General IH Tech' started by Mastiff, Jun 8, 2010.
  1. Mastiff
    Mastiff Binder Driver
    Sep 15, 2007
    634
    Tucson, AZ
    I know I really wanted a pic like this when I was deciding what to do. This is with the 2.5" Mr Scout springs plus 4" shackles from IHON. I figure it nets about 3" total lift. I ordered 32x9.5 tires, hope they fit. The tires in the pic say 30" but they measure 29.
  2. Fred Demmon
    Fred Demmon Y-Block King
    Jul 26, 2006
    3,578
    32
    Pearland TX
    I have a 65-80 also.
    What was the total cost of the springs and shackles with shipping?
  3. Mastiff
    Sep 15, 2007
    634
    Tucson, AZ
    I got the kit which has springs, bushings, U-bolts and shocks. That was $850 plus a little over $100 to ship. Shackles were from IH Only North. I think they were $50 a pair. They are ridiculously heavy duty.
  4. kb'sforme
    kb'sforme High Wheeler
    Jul 16, 2008
    1,010
    houston,tx
    what else is needed. any shims to corect alignment? or extended brake lines? i know thats not a lot of lift just wondering.
  5. Mastiff
    Sep 15, 2007
    634
    Tucson, AZ
    I put 4* shims, but I'm not totally sure they are necessary. The shackles will change caster for the worse and shims can put it back the other way. I don't think longer brake lines are required, at least not in my case. I'm not sure if my lines are original, but it looks like the shock will bottom out first. I plan to double check all this stuff before doing any serious off-roading though.
  6. guidolyons
    guidolyons High Wheeler
    Jul 5, 2006
    1,785
    143
    Corpus Christi, TX
    :beer:
    Good before and after pics :yes:
    The Scout is lookin' good, post up another pic when you get the new tires on it.
  7. tdc
    tdc Y-Block King
    Sep 8, 2005
    3,028
    650
    Central Oregon
    Looks tuff. Stock Rubber brake lines stretch and blow out. Check them at full articulation. :beer:
  8. scorp1us
    scorp1us High Wheeler
    Jul 28, 2009
    1,495
    Baltimore, MD
    Nit-picking, but shims don't correct alignment, they correct caster.
    My 4" lift required a longer rear line, but the fronts are ok. I'm still going to replace them though, because my replacements are stainless.
  9. Mastiff
    Sep 15, 2007
    634
    Tucson, AZ
    I was wondering if I should get some longer bump stops with the lift. What do you guys think?
  10. HillRaiser
    HillRaiser Farmall Cub
    Jan 23, 2007
    259
    Hutto, TX
    I have about the same lift on mine and I am running 32x11.50 GoodYear MT/Rs. I get a little rub at full flex, but other than that, they run OK.
  11. Mastiff
    Sep 15, 2007
    634
    Tucson, AZ
    Here's a shot with the new skinny 32" tires (235/85R16). I can't pull it out because my carb is getting worked on.
  12. eightOsix
    eightOsix Binder Driver
    Apr 30, 2007
    633
    21
    Fraser, CO
    Looks nice. I like the narrow tires. What wheels did you go with?
  13. Mastiff
    Sep 15, 2007
    634
    Tucson, AZ
    Just steel wheels, 7" wide, 4" backspace.
  14. chrisp80
    chrisp80 Farmall Cub
    Jun 17, 2007
    san leandro, CA
    scout looks good... i like the skinny tire look too! right on!
