Motor oil: current recommendations?
Discussion in 'General IH Tech' started by theloneduck, May 22, 2020 at 11:33 PM.
  1. theloneduck
    theloneduck Farmall Cub
    Nov 24, 2013
    478
    80
    Arkansas
    I know it used to be rotella t-3 but what’s the recommendation now?
  2. scout2000
    4,673
    1,369
    You kind-of left things wide open there.
    Between the Rotella comment and your signature line with a '79 S2 listed, I'm assuming you probably mean for a Nissan diesel or turbo diesel.
    I have a Cummins 6BT powered vehicle and I Rotella myself.
    OTOH, I suppose maybe you could have an IH SV V8 or inline 4, but probably not the AMC inline 6. I believe that those were out of the picture by 1979.
    What do you need oil for?
  3. theloneduck
    Nov 24, 2013
    478
    80
    Arkansas
    Sorry. It’s a 79 scout 2 with a v8 345
  4. mallen
    mallen Y-Block King
    3,151
    682
    A CJ/SN 15W40 oil with 1200ppm zinc works well. My owners manual recommends 20W40. The 15w range is almost completely a subset of 20W. CK oils I believe have the zinc removed, so they are out. In fact many diesel engines specify they should not be used. Google u the petroleum quality institute and look for ones they tested that have 1200ppm zinc. Be careful, often the bottles look the same except they now say ck instead of CJ. You want the "universal" oil that works in both spark and compression ignition engines. (It will say its for both on the label and be rated both ck and sn)
  5. BinderBookie
    BinderBookie High Wheeler
    Apr 25, 2014
    2,451
    1,059
    A Farm in Ohio
    Sorry, you got that backward Captain Sacto (remember him?). It's the CK4/SN that dropped the ZDDP to get the dual purpose rating. The CK is still holding at between 1050 and 1200 ppm , depending on brand.
  6. RinTX
    2,107
    652
    I use Rotella T4.
  7. theloneduck
    Nov 24, 2013
    478
    80
    Arkansas
    Got it. I knew there had been some changes, just couldn’t find what they were. Thanks!
  8. MrKenmore
    MrKenmore Y-Block King
    3,418
    1,173
    Shell Rotella T4 15W/40
  9. winchested
    3,239
    1,188
    15w40 with a little bottle of zddp dropped in is fine too.
    Lucas hot rod oil is high zddp too. Cheap at the local Napa. I just run cheap brand 15w40 diesel oil from the Cdn tire.
  10. 2dafloor
    2dafloor Farmall Cub
    Dec 9, 2012
    140
    knoxville
    You ll all die but I still run Havoline 10w40 on all my older STOCK flat tappet cams....im a horrible person I understand. Not a big fan of 15 w oils on start up on gas motors.
    0w40 Mobil one euro formula in my Gen3 hemis and LT4 engines.
  11. Ron A
    Ron A High Wheeler
    Jan 11, 2003
    1,189
    331
    State of Jefferson
    Valvoline VR1. If you are thinking 15-40 is to heavy.
  12. scoutdude
    scoutdude Farmall Cub
    Jan 31, 2018
    136
    Texas
    I got some Amsoil Zrod. Has plenty zinc and a lot of additives to help with older cars that don’t get driven a lot. It’s 10 30
  13. TravelerMan79
    TravelerMan79 Farmall Cub
    Apr 15, 2020
    174
    54
    Ottawa, ON
    Good thing I read this thread as I was going to dump some 10W30 into her once I had a chance. Most of my Land Cruiser buddies run the Shell Rotella 15W40 in their diesels. Damn some of that was just on sale locally.
  14. Ron A
    Ron A High Wheeler
    Jan 11, 2003
    1,189
    331
    State of Jefferson
    Had to look him up. Before my time, but not before Ted Ornas time.
    [​IMG]Captain Sacto was a 1950's and 60's childrens' show hosted by Harry Martin as Captain Sacto, for KCRA Channel 3 Sacramento, California (USA) showing such animated show like "Crusader Rabbit).
  15. 2dafloor
    Dec 9, 2012
    140
    knoxville
    I ran the Traveler brand 15w40,its Tractor supply brand, in the 345. Lots of smoke and lots of valve train noise. Swapping back to my trusty 10w40 killed all that. I used the last jug on my old 318 with a bad rear main seal leak and it smoked like a chimney and the acrid smell. I really should have given that away.
  16. winchested
    3,239
    1,188
    That's not the oils fault. That's a worn out valvetrain.
    My 345 hasn't burnt or used a drop of oil in 1000 miles.
    2dafloor likes this.
  17. Tom Mandera
    Oct 19, 2001
    4,362
    70
    Helena, MT
    On my stock Scouts, I run whatever is handy - if I remember, I give it some Comp break-in additive for the extra ZDDP.
    On the high-zoot 'binders, it's was Valvoline VR-1 Racing, but when the parts store didn't have any 10w30 in the back, I switched to ordering Brad Penn.
  18. mallen
    mallen Y-Block King
    3,151
    682
    Some things wrong. That's not a slight difference. That's huge. Since it doesnt happen on most peoples it suggests there's something quite different about your engine. ID want to get to the bottom of why the thicker oil (which is within specs of oils recommended by ih) causes severe problems. Was it really cold? Obviously , if it doesnt work, you use what does, but something odd like that makes me wonder whats going on. I never used the traveler oil myself before last week. I ran it and idled it for about an hour and OT sounded great with no smoking or anything. Well after the initial smoking , but that was expected. Water had gotten into two of the cylinders and the motor was stuck. I had to vacuum out the water and put transmissiion fluid in the cylinders for a day and then rock it back and forth in gear until it finally came loose and vomited up chunky rusty water and oil all over the place. But then it started and actually runs really good after the tranny fluid burned off. And that's with the traveler 15w40
  19. 2dafloor
    Dec 9, 2012
    140
    knoxville
    Correct,were talking a 1975 345 and a 1978 318. Not every engine I own is brand new.
  20. BinderBookie
    Apr 25, 2014
    2,451
    1,059
    A Farm in Ohio
    I grew up in Sacramento, so I remember Harry Martin/Captain Sacto. We had the same dentist so I actually got to meet him a few times as a kid. There was another guy that did late night scifi that I can't remember.
