Metal etch prior to painting?
Discussion in 'General IH Tech' started by grannygear, Feb 6, 2004.
  1. grannygear
    grannygear High Wheeler
    Jan 8, 2002
    1,127
    Castaic, CA
    I will be painting some bare metal (roll cage, bumpers, etc) and I would like to texturize the surface a bit for more 'stick' for the spray paint.
    I am aware of the Metal Prep product from POR 15, but it seems to me that I had read there was a simple chemical solution substitute that was equivalent and cheaper.
    Any advice on a good way to do this, or should I just order the Metal Ready?
  2. harleykeith2003
    harleykeith2003 Binder Driver
    Apr 6, 2003
    813
    Ardmore Oklahoma
    prep
    Try Picklex 20 I looked at it and it sounds great if it works and not too costly
  3. doggone
    doggone Farmall Cub
    Apr 17, 2003
    60
    Wilmington, NC
    I just got done taking the hood and top down to bare metal on my scout this week. My buddy is a painter, and he is going to use an acid-etch primer. This primer has a hard, glossy finish, compared to the chalky red-oxide primer. I am not sure of the exact paint #, it is Nason by DuPont,
    HTH
  4. MikeInMobile
    MikeInMobile High Wheeler
    Oct 22, 2001
    2,848
    Mobile, AL
    Phosphoric Acid.
    I buy it at Home Depot, brand name OSPHO. 5 or 6 bucks a quart.
  5. grannygear
    Jan 8, 2002
    1,127
    Castaic, CA
    THAT"S THE STUFF I was thinking of!
    Cool. So that will be a good pretreatment for spray painting stuff?
    Do you mind sharing how you go about using it? Is this non-caustic stuff?
  6. 1973 in pieces
    1973 in pieces Farmall Cub
    Oct 14, 2002
    366
    Alabama
    Ospho is Phosphoric Acid it will burn you if not carefull you can just wipe or bush it on.
    Tom L.
  7. grannygear
    Jan 8, 2002
    1,127
    Castaic, CA
    OK. What about respiration? Also, does it wash clean with water?
    So, it would go like this:
    Good gloves, breathing, and skin/eye protection; wipe on and allow to dry, wash off with water, towel dry to prevent any rust and then break out the Krylon?
    Sound right?
    The Metal Ready from POR 15 is advertised as non-toxic, non-caustic, etc. Apprently it is more than just phosphoric acid.
  8. EagleMark
    EagleMark Banned
    Dec 18, 2001
    1,169
    North Idaho
    Self etching primer in spray cans from NAPA
  9. grannygear
    Jan 8, 2002
    1,127
    Castaic, CA
    Yeah. I have tried that. I did not think the results were worth the cost of the pricey primer, although I bought mine from an auto body supply house.
    I like the idea of the metal etch as long as I can figure it out.
  10. MikeInMobile
    Oct 22, 2001
    2,848
    Mobile, AL
    I pour the OSPHO in a plastic bowl/bucket, brush it on with a paint brush, let dry, and paint/sand/bondo over it. Pour what you dont use back in the bottle. Keep it sealed or it will evaporate.
    Tom is right, ( I gotta get that SII wheel from you Tom :D) it will burn, kind of like a battery acid burn. Starts as an itch, progresses to a sting, then its like, hey, that stuff burns! :D
    Rinse it off your skin and you are fine, except for the red spot.
    Dont rinse/wash it off the metal. Leave the residue after it dries and paint right over it. Sand or bondo over it too. The residue continues to inhibit rust development in my experience.
  11. grannygear
    Jan 8, 2002
    1,127
    Castaic, CA
    Great. That really helps. I will have to head to the local Home Depot and see what i can find.
  12. urbanassault
    urbanassault Farmall Cub
    Nov 24, 2003
    68
    Dallas
    Self-etching primer is mainly for bare aluminum and alloys it doesn't really have enough strength to etch steel products.
