Melting rotor
Discussion in 'General IH Tech' started by Scott80, Aug 15, 2019.
  1. Scott80
    Scott80 Farmall Cub
    Mar 6, 2019
    51
    Scout 80 152 1962
    Have had the mad ignition in for a while, ran good. Noticed it started to bog down. Under cap shows some melting.
    Every box store lists the wrong one.
    Looking for a quality brand like Accel, petronix or summit for a new distributor cap and rotor
    Any part numbers would be very helpful
    Thank you
  2. 1975IH200
    1975IH200 Y-Block King
    3,248
    531
    Which distributor do you have ?
  3. jeff campbell
    15,453
    1,552
    20190416_085928.jpg Show us a pic of yours.not the cap. Side view of the top of the body of dizzy. Below the cap.Holley curved points
  4. jeff campbell
    15,453
    1,552
    Mad or mad ignition ?
  5. mallen
    mallen Y-Block King
    3,465
    837
    Edit: NVM, you have a 4 cylinder. Just go to rock auto, they should list one. Thats the best you will probably get.
  6. Scott80
    Scott80 Farmall Cub
    Mar 6, 2019
    51
    Msd ignition.. auto correct
    My problem is it can't handle the heat
  7. Dana Strong
    5,691
    1,426
    I'm not familiar with that term, but from looking at your picture, am wondering if the rotor damage is because the rotor position is far from being near a plug-wire terminal in the cap, so the spark is jumping sideways over the plastic to get there, or perhaps even jumping to ground below.
    When rotating in the correct direction and the points are just opening, where is the rotor pointing wrt the terminals?
  8. jeff campbell
    15,453
    1,552
    Thx I meant msd
  9. winchested
    3,472
    1,289
    Is it just an MSD coil? Or do you have some sort of MSD digital box?
  10. Scott80
    Scott80 Farmall Cub
    Mar 6, 2019
    51
    Digital box
  11. 1975IH200
    3,248
    531
    You have a Holley distributor. This is info you can provide to the clerk at an Auto Parts store.
    Cap - Standard Motor Products p/n IH443.
    Cap - Airtex/Wells p/n 5D1175
    Rotor - Standard Motor Products p/n IH318
    Rotor - Airtex/Wells p/n 4R1073A
    EDIT: You DO NOT have a Delco-Remy distributor.
    EDIT: You DO NOT have a Prestolite distributor.
    EDIT: You DO NOT have a Mallory distributor (aftermarket).
    EDIT: You DO NOT have a Davis DUI distributor (aftermarket).
    EDIT: You DO NOT have a Lucas distributor (aftermarket).
  12. patrick r
    patrick r Binder Driver
    Aug 23, 2005
    932
    429
    Zionsville, IN
    Is this the first time it’s happened? I run a box (summit) with a delco distributor and have not had a problem like this. I don’t know what the options are for the Holley cap/rotor but would check Napa.
