M-5H-6 6x6 Serial Number Registry
Discussion in 'IHC Military Vehicles' started by Dave Ball, Oct 19, 2009.
  1. Dave Ball
    Dave Ball High Wheeler
    Aug 22, 2005
    1,270
    Saratoga, CA
    This thread is for all to post serial number and Delivery date info for the WW2 International 6x6 trucks.
    please stay on that topic in this thread. (thank you)
    If you know the the service arm or branch such as USMC or Navy please include that info as well as if the truck is a cargo, dump, Long wheel base, Short wheel base or other type of body, chassis.
    Also please include the regitration number if you have it.
    The collection of this info is to help others fill in the blanks or give them an idea of the range in which there truck falls into for build date and registration numbers as well as to collect survivor numbers and change info such as for example trucks built with wood or metal beds and the date or even serial number that International changed over to installing wood beds. Collecting this change info will help those seeking to have there truck as factory correct as possible to do so.
    Thanks
  2. Dave Ball
    Aug 22, 2005
    1,270
    Saratoga, CA
    Re: M-5-6 M-5-4 and M-5H-6 SN and Date of Delivery Registry
    I will start this off:
    M-5H-6, Cargo, 2 1/2-3 ton
    Date of deliery 11-44
    USMC
    Serial Number 15586
    Metal bed, Long Wheel Base
    Registration number ?
  3. russell moore
    russell moore Farmall Cub
    Jun 10, 2009
    29
    Reidsville NC
    M5H6
    DOD 12-44 Cab and Chassi never stamped for model
    Serial # 22940
    Hood # USMC 92652
    Long wheel base
  4. George Yingst
    George Yingst Farmall Cub
    Oct 16, 2007
    417
    30
    Deer Park, Wa.
    I'll start with the earliest one and work my way forward.
    m5h6
    serial # 5186 (from frame-no body panels left)
    Unk anything further--frame stretched post war
    The only truck I have with finned rear differential covers
    navy grey paint on whats left
    m5h6
    serial # 26151
    dod- 4-45
    USMC cargo--frame stretched post war
    m5h6
    serial # 27914
    dod- 5-45
    USMC cargo LWB
    "USN 209172" on doors
    m5h6
    serial # 29359
    dod- 6-45
    m5h6
    serial # 31013
    Unk further-cab changed/frame stretched post war
    Thats all for now:)
  5. hanselandgretel
    hanselandgretel Farmall Cub
    Oct 18, 2009
    80
    Claremont, MN
    Hi George. Where did you find a number on frame? I found one on a fire truck conversion, but it doesn't match dash plate number or make any sense. It was by the left front spring hanger on the ouside of the frame. Only on this one I found a number though, not on any of the other 4 or 5 I have. Thanks
  6. hanselandgretel
    Oct 18, 2009
    80
    Claremont, MN
    001.JPG View attachment 122028 Re: M-5-6 M-5-4 and M-5H-6 SN and Date of Delivery Registry
    M5H6, Long wheel base
    Seat tag, present but paint covered
    Dash plates, 2 1/2-3 ton 6x6 Radio, USN, IH M-5H-6-361, s/n 19629, dod 9-44.
    Modified to Fire truck by Maxim Motor Co, their s/n 1570
    Number stamped in frame by left front spring hanger 72-00256, another number stamped in frame same as dash tag, 19629
    Round metal tag, 1 1/2" diameter, riveted to cab 4" ahead of drivers door and 6" below top hinge, 003889, SH276
    How can I get the info off of the seat tag without destroying it?
  7. George Yingst
    Oct 16, 2007
    417
    30
    Deer Park, Wa.
    First off, sorry to hanselandgretel for not paying any attention to this post for a long time. That frame number seems all off to me that you found. I've never seen one without the frame number and they are quite large by todays standards. All are stamped by the left front spring hanger.
    Not sure how to get info from the plates either without damage.
    On to my latest treasure:
    M5h6
    serial # 29647
    DOD 6-45
    USMC cargo
    LWB--no bed left
  8. Dave Ball
    Aug 22, 2005
    1,270
    Saratoga, CA
    1945 M-5H-6 (WOW) Refueler serial no. 39341 date of delivery 1-45
    maybe 4-45.
    Missing original tank and pump set up as a logging truck with trailer.
    WOW = without winch
  9. Dave Ball
    Aug 22, 2005
    1,270
    Saratoga, CA
    I am parting and scraping several trucks and I will add their frame numbers here to the registry as I do it.
    If I sell the frame or rolling chassis as a part I will leave it up to the new owners to add them here. I am doing this in hopes that we will get a list of trucks that have been found and what there status is.
    I am also making this a sticky note so it will be at the top of the list where others can find it easily and add there M-5H-6 trucks to the list and the status such as Parted and scraped, under going active work to get it back on the road or sitting waiting for work to begin.
    So please add your truck here no matter the status or final plan for it.
  10. Dave Ball
    Aug 22, 2005
    1,270
    Saratoga, CA
    I have been working on parting some M5's and the first one that is going to the metal eater is the one pictured here serial number 11279, it was built as a USN tractor on a contract of 220 and although you can just makeout the engraving on the data plate I believe it says 1943.
    As you can see I took everything I could get that was not FUBAR'ed.
    The frame was cracked and repaired in many places and the winch horns removed and then added back. The motor is a RD501 down draft.
    I am not taking the cab as the back is roached at the bottom and their are numerous big dents and holes. This truck sometime in its 70 year lifespan had it ujoints and yokes changed over to Spicer from Mechanics. I saved the yokes that were there and the drivlines.
  11. youric
    youric Farmall Cub
    Oct 17, 2014
    79
    Austin, TX
    M-5H-6
    S/N: 23489
    DOD: 2-45
    USMC
    Cargo (WOW, despite tag indicating otherwise, perhaps removed?)
    Was purchased from Ft. McCoy in Wisconsin in the 1950s with a well-drilling rig on back. When I found it, it had a Belt-Link crane on it, now it is bare frame. I believe the wheel base has also been extended. Has a civilian K/KB cab, civilian gauges, etc. Still has original air compressor fully functioning.
  12. hanselandgretel
    Oct 18, 2009
    80
    Claremont, MN
    DSC_0320.JPG DSC_0311.JPG DSC_0312.JPG M5 Wash2.jpg Purchased in WA state, 6-15, M5H6 cargo, metal box, with winch. DOD 7-45, Frame and dash tag s/n 31435, tag on seat mounting frame by drivers door says "Model HEAK-32255. What does the seat tag mean?
  13. George Yingst
    Oct 16, 2007
    417
    30
    Deer Park, Wa.
    My latest M5H6.
    Serial number 27697. 1125161319_resized.jpg taken from frame. glove box door with data plate was moved to the civilian cab on it, but so rusted I can't read any of it.
    149" wheelbase. Frame pretty compromised, will likely end up as a parts truck.
    George
  14. Cowboy101d
    Cowboy101d Farmall Cub
    Apr 9, 2017
    31
    M5H6
    Serial number 23480
    Contract #NOm-43833(Thanks George! )
    Haven't found any other numbers yet
    Long Wheel base truck more info to come as I start the tear down
  15. Cowboy101d
    Apr 9, 2017
    31
    Here's a picture of my truck to go with above post
  16. George Yingst
    Oct 16, 2007
    417
    30
    Deer Park, Wa.
    Newest toy..
    M5H6
    serial # 26475
    D.O.D. 4-45
    USMC lwb cargo
    Can see faint USN number on the doors and a seebea insignia on drivers door. Attaching photo of the serial plate and bed data plate. cal1.jpg 1202181543d_resized.jpg
  17. Spec4don
    Spec4don Farmall Cub
    Mar 21, 2019
    Model 2 1/2 -3 ton 6x6 Cargo
    IHC M-5H-6-361
    US Navy
    S/N 18219
    DOD: 1-45
    Green paint, the frame is stretched and doubled.
    Eugene Oregon
    Don G.
  18. George Yingst
    Oct 16, 2007
    417
    30
    Deer Park, Wa.
    This one finally made its way home. The well drilling rig was removed by the previous owner.
    Frame serial # 29026 (should put it at 5/6-45 delivery date)
    Was a lwb truck. Data plates are all gone along with the original cab. Frame has been stretched but was done very well. Not sure what to do with it yet. Supposed to run and has been converted to propane. well driller 4.jpg
  19. Pintelhook11over
    Pintelhook11over Farmall Cub
    Jan 25, 2020
    Hello everyone,
    I got my first 6x6...
    A M-5H-6!!!
    Adding my serial to the registry
    DOD 4-45
    Serial Number: 26604
    Has winch
    1000 gallon water tank welded on frame with Fairbanks-morse water pump welded on the right side frame, spray bars on aft and Port side
  20. gmcjimmy1944
    gmcjimmy1944 Farmall Cub
    Jan 18, 2005
    53
    Taunton,MA
