Looking for Scout 800 Washer Bracket
Discussion in 'General IH Tech' started by 76rallye, Feb 13, 2018.
  1. 76rallye
    76rallye Farmall Cub
    Sep 20, 2010
    122
    Marblehead,MA
    Wondering if anyone out there has a Windshield Washer Tank Bracket, PN 397 392 C11, for a Scout 800 that they wanted to sell?
    This bracket mounts to the firewall which hold the reservoir tank. If not does anyone have a workaround?
  2. Brokegunner
    Brokegunner Farmall Cub
    Oct 7, 2017
    90
    22
    Valley Springs, CA
    I have a 69 800A I'm parting out and i know it has a washer tank bracket. I can take a pic tomorrow.
    Sent from my SM-T817V using Tapatalk
  3. joewatkins
    joewatkins Farmall Cub
    Jan 3, 2017
    193
    Willis Texas
    If his falls out I have one in my truck that will go. I have no need for it. Pm me if needed
  4. 76rallye
    Sep 20, 2010
    122
    Marblehead,MA
    Thanks again for the two people that offered one they had but unfortunately, I need the one that's mounted on the firewall not for the circular bottle on the fender. Pic attached.
      File size:
      292 KB
      35
  5. marduk101567
    marduk101567 Farmall Cub
    Jan 28, 2016
    53
    Looking for one as well
  6. MuttMike
    MuttMike Farmall Cub
    Mar 1, 2004
    219
    44
    Woodcrest (So Cal)
    The image you posted shows only one of two bracket pieces that are required to hold the tank. There is the bracket (shown) that bold to the FW, where earlier models had their ID/Serial number plates and a 2nd bracket that bolts to the first that features a "V" shaped gismo that holds the plastic tank.
    Do you need both brackets or just the one that connects to the FW?
  7. 76rallye
    Sep 20, 2010
    122
    Marblehead,MA
    The scout didn't come with a tank.
    The photo I posted was from the parts book and my ID Tag is on the Door. So I guess just the one bracket.
  8. MuttMike
    Mar 1, 2004
    219
    44
    Woodcrest (So Cal)
    You would need both brackets to hold an IH OEM tank. If you don't have any of the original parts, aftermarket/univesal maybe the way to go. If not I could give you/post a drawing and pictures of mine so you could make your own, as this is style is quite rare (ie not the round bottle type).
    Let me know.
  9. 76rallye
    Sep 20, 2010
    122
    Marblehead,MA
    Good to know. I ordered a tank and washer that may be a good substitute. Once rcvd I'll confirm and share the info. Perhaps I can mount it directly to the firewall just spaced over a tiny bit getting rid of the need for the brackets.
  10. 76rallye
    Sep 20, 2010
    122
    Marblehead,MA
    UPDATE: The Parts Manual calls out a PN 394120C91 for the Washer Tank. Doing a search online, I found that same number is used on a IH School bus.
    tacbusparts.com had a Washer Tank and Pump for $29 plus shipping. There is no IH Logo. I did not have the required mounting plate but I was able to drill two holes for the upper mounts and utilized the lower right master cylinder plate (not sure exactly what that's called) bolt for the bottom mount. The left bottom tab I just cut off. Fits perfectly and didn't spend a fortune.
      File size:
      53.4 KB
      21
      File size:
      59.7 KB
      21
