Looking for good machine shop around KC
Discussion in 'General IH Tech' started by NEWOLDIRON, Nov 16, 2008.
  1. NEWOLDIRON
    NEWOLDIRON Farmall Cub
    Feb 10, 2008
    Kansas City
    Looking for a good shop in the Kansas City area experienced with IH engine overhauls.
    Thanks,
    Scott
  2. nekbinders
    nekbinders Binder Driver
    Jan 5, 2005
    700
    Reserve, KS
    Looking to do a stock rebuild or some performance. We have experience with IH engines. Unfortunately we don't do our own machining. There used to be some good engine shops in KC. G&G is one that comes to mind. Not sure if they are around any more.
  3. NEWOLDIRON
    Feb 10, 2008
    Kansas City
    Not really looking for serious performance, just a good overhaul and some upgrades, multi angle valve grind, heavy springs, balance, exhaust p&p.
    Going to restore our 78 scout in the spring but traveling for work is going to drag it out if I dont sub some of the things I usually do myself. It's difficult to let some one else monkey with a family jewel, but I have decided to be practicle and would prefer to have use of it back sooner, rather than spend a year without it.
    Scott
  4. BinderMark
    BinderMark Farmall Cub
    Mar 20, 2003
    67
    Louisburg, KS.
    For your head work, you might try:
    Noland's Cylinder Head Service
    1519 Charlotte
    K.C., MO.
    816/471-5167
    You might ask Tom at Noland's where to go for the rest of the engine work.
    And then there is:
    Roadbuilder's Machinery and Supply
    1001 S. 7th
    KC.,KS.
    913/371-3822
    Hope this helps.
    Mark
  5. R290
    R290 High Wheeler
    Apr 25, 2005
    1,313
    Sacramento, CA
    I used a local I.H. engine builder. IHOnlyNorth, Jeff had a racing machine shop do the machine work. They did the light porting, and machined everything to spec and balanced to 1 gram. He order a rebuilt rocker assy. and put it all together. It was not cheap, but it cost to have good work done. There are a lot of little things with IH engine that you need to spend time making sure it's done right as they have a unique oiling system. Jeff had just switched machine shops and this was his first complete engine rebuild with that machine shop and he was very happy with there quality of work. You will want to use the Silvolite piston's. I would also recommend you run a quality oil like Swepco 306. You might want to even look on the this forum for ideas too. If you rebuilding the motor don't forgot to replace those motor mounts :)
    http://www.ihonlynorth.com/forums/
  6. NEWOLDIRON
    Feb 10, 2008
    Kansas City
    Thanks for the info and all the advise fellows.
    Scott
