I just did a bunch of brake lines. They are not hard, if you have a good tool The ones from the parts stores and the cheap ones from HF are just garbage. They dont hold the tube well and they have too course of thread on the bolt so it takes excessive effort to flare the tubes. I borrowed an old one that someone thought was the "loaner" that they would not care about losing vs their shiny new craftsman. It was an old Imperial 93FB, made in the USA. It was night and day. I never realized what a proper flare tool should actually work like until I had used that one. (I told him, under no circumstances loan that out again, because you might never get it back) I went out and bought one on ebay for 20 dollars, missing the dies, and bought a set of gear wrench dies on Amazon that fit it for 15 dollars. Id never use anything else. They are still available new, but I bet the old ones are better. (they certainly look it). If go that route, look at what your buying carefully though. I noticed that many of them have only one peice of the tool ,the part that grips the tube , original, and the other half is actually some no name part. Both parts, the one that grips the tube, and the part with the screw that flares the tube, should be marked imperial. It probably would not be a bad way to go to buy a brand new one. A google search shows that they are highly regarded. Im cheap though, and I like old tools.
The way a double flare tool works is that you cut the tube with a tubing cutter, then remove the burr. There is often a part of the tubing cutter for that. I prefer I file. Then you clamp the tube in the clamp part of the tool,and use the edge of the die to measure how much is protruding. Then you put the pin of the die in the tube. The die has a tapered dimple in it for the cone shaped end of the other part of the tool. You place that over the clamp and use it to crush the end of the tube into something that looks sort of like the bubble flare on foreign cars. Once you have that done, remove the die and then run the cone into the bubble flare to create a conical flared seat. If you dont do the first step you wont have a good seal and its likely to fail under use, sometimes catastrophically under the pressure in a brake system.
You also need a decent tubing bender. I actually liked the "OEM" brand tubing bender that autozone rented me. It seemed to work quite well. It was one of the one that has grooves for each size tubing and supports it all around, like this one
https://www.autozone.com/loan-a-tools/loaner-tube-bender/oem-heavy-duty-tubing-bender/391367_0_0
and not one of the worthless ones like this one
https://www.autozone.com/loan-a-tools/loaner-tube-bender/oem-tubing-bender/48587_0_0
