Kayline top install on SSII
Discussion in 'SSII' started by genelynn1962, Oct 29, 2013.
  1. genelynn1962
    genelynn1962 Farmall Cub
    Oct 27, 2010
    100
    Clare,Mi
    Is anyone running a Kayline top on a SSII that can verify where the snaps for the back upper panel are to be located? I've got a NOS top, never installed that didn't come with directions but it appears that the two outer snaps would go into the rear corner caps and the other 5 go into the tailgate. Is this correct? Thanks for any help! Greg
  2. JasonR.
    JasonR. Binder Driver
    Apr 19, 2003
    601
    St. Louis, MO
    Not sure if this is the question you'rea asking, but....
    There's a piece of angled aluminum that runs the length of the tailgate and mounts to the beveled lip. That piece should accomodate the snaps that run along the bottom edge of the top's back window/flap.
    On that flap, the two outboard snaps (left and right) should mount to the top hardware's aluminum rails that run along each side of the body. That said, your body panels and tailgate have to be pretty well lined up to make that happen.
  3. genelynn1962
    Oct 27, 2010
    100
    Clare,Mi
    Jason, Thanks for the information, very detailed! I'll have to see if I've got that aluminum piece that fastens to the tailgate. Greg
