Is it fit or not ??
Discussion in 'Triple Diamond Trucks' started by zero_h, Mar 13, 2017.
  1. zero_h
    zero_h Farmall Cub
    Mar 13, 2017
    I measure my axle diameter is 220mm,bolt pattern is 190mm
    My truck could fit this one???
  2. michael sharp
    michael sharp Farmall Cub
    Feb 12, 2017
    216
    Park Rapids, MN
    WHAT?????????
  3. zero_h
    zero_h Farmall Cub
    Mar 13, 2017
    this is my heavy duty truck rear axle
  4. michael sharp
    Feb 12, 2017
    216
    Park Rapids, MN
    I mean "this is my heavy duty truck rear axle" tells us nothing. What do you have? Why is your axle wider than the bolt pattern? Do you want rims, axles you didn't make it clear. Thats why I said WHAT!!!!!! AND why use mm and show inches? This just looks like a 3/4 or 1 ton. What year?
  5. zero_h
    zero_h Farmall Cub
    Mar 13, 2017
    Sorry,I didn`t explain clear,
    I want to change my rim ,but I don`t know this rim (AERO CLEAR) could fit my truck??
    This is my heavy duty track HINO 17ton
  6. Darrel
    4,440
    901
    Your Japanese truck has a metric bolt pattern and the wheels you posted are imperial (English/American) so they won't fit. Your best bet is to visit a wheel store or call the wheel company. Also this website is for International Harvester vehicles only.
  7. zero_h
    zero_h Farmall Cub
    Mar 13, 2017
  8. bindermike
    bindermike Farmall Cub
    Apr 6, 2003
    253
    Lorton, VA
    The Aero Clear are see-through plastic wheel covers to improve fuel mileage. They are not wheels. Are you looking for wheels, or wheel covers? Where are you located?
    zero_h and Darrel like this.
  9. zero_h
    zero_h Farmall Cub
    Mar 13, 2017
    that can fit my wheel or not??
    I`m looking for wheel covers
    I`m from Taiwan
  10. bindermike
    Apr 6, 2003
    253
    Lorton, VA
    There's a good chance they will fit, if you have 22 inch diameter wheels. You need to measure your axle bolt diameter (see the photo).
    There is a youtube video on installation and removal here,
    I would recommend contacting the manufacturer, RealWheels, to find out for sure. Their contact web page is http://www.realwheels.com/contact/
    Good Luck, Mike
    zero_h likes this.
  11. zero_h
    zero_h Farmall Cub
    Mar 13, 2017
    I have a question about "universal bracket"
    is it both fit 5/8" & 3/4" axle bolt ??
    Or 5/8" axle bolt only fit 5/8" universal bracket & 3/4" axle bolt only fit 3/4" universal bracket??
    thank you very much
  12. bindermike
    Apr 6, 2003
    253
    Lorton, VA
    The diagram shows my thoughts on the brackets, but you should contact the manufacturer to be certain if the wheel covers will fit your Hino truck.
    Good Luck, Mike
