In-line 6 - 345 swap
Discussion in 'Anything Scout' started by Owen76, Nov 28, 2018.
  1. Owen76
    Owen76 Farmall Cub
    Nov 9, 2018
    Hello,
    I have a 71 scout 800B with an in-line 6 that needs a rebuild and a "tractor like" four speed. I have always dreamed of putting a 345 V8 and 4 speed from a scout II in it as the scout II drives so much nicer than scout 800s.
    Recently I was offered a great deal on a really solid driving scout II with a 345 and 4 speed. So now I have the opportunity to do what I always wanted but this is a much bigger project than I've ever done and I won't have the two scouts next to each other unless I buy this one so I can't compare details.
    My question is:
    -has anyone reading this done this?
    -If so, what are the major obstacles I will hit?
    -my major conserns are:
    -different motor mounts
    -transmission mounts
    -Clutch opporation
    -radiator compatibility or room for 345 radiator swap
    If this is possible, the next steps I would want would be:
    -swap the 4x4 transfer case
    -swap axles
    -add power steering
    -anything else I can swap to make an 800 drive a little nicer
    Is any of this possible or do I sound like an idiot?
    Is there a website or YouTube channel that I can find instructional videos?
    I have a mechanically inclined friend who knows scout IIs pretty well but he is not going to do the research for me so I need to have my ducks in a row before I buy the parts scout.
    Thank you very much for any help.
    Josh800A likes this.
  2. MrKenmore
    MrKenmore Y-Block King
    3,049
    910
    Post this over in General Tech forum for more exposure.
  3. Owen76
    Owen76 Farmall Cub
    Nov 9, 2018
    Thanks
  4. Josh800A
    Josh800A Farmall Cub
    Mar 21, 2018
    142
    51
    Good luck with your swap. I have the six, AMC 232, same as you, but with a three speed. Can I put in my dibs for your four speed? Where are you located?
    Thanks,
    Josh
  5. Owen76
    Owen76 Farmall Cub
    Nov 9, 2018
    Santa Fe N.M.
    I'll try to keep this post to remember you. It may be a bit till I do the surgery as winter is rolling in and my workspace is outside.
  6. Chops24
    Chops24 Farmall Cub
    Nov 26, 2018
    19
    I’m in Albuquerque with a scout II if you need measurements or have questions
    Owen76 likes this.
  7. Josh800A
    Mar 21, 2018
    142
    51
    I can wait.... :yes:
    Thanks,
    Josh
