IH 392 cylinder numbering order 8-7- etc...
Discussion in 'General IH Tech' started by sdowney717, Dec 10, 2011.
  1. sdowney717
    sdowney717 Farmall Cub
    May 20, 2004
    375
    Newport News, VA
    Would like a diagram showing the numbers
    OK, looking at a motor, where is number 8 etc....
    thanks
  2. Will Marsh
    Mar 6, 2001
    3,312
    Loveland, CO
    radiator to firewall
    2-4-6-8
    dist/carb
    1-3-5-7
    1 and 2 are closest to the radiator, 7 and 8 are closest to the firewall
    Firing order is 1-8-4-3-6-5-7-2, timed on #8
    HTH,
    Will Marsh
  3. scoutboy74
    4,876
    208
    The even bank of cylinders 2-8 are on the left side and the odd #'s 1-7 are on the right side when viewed from the front of the vehicle on all IH SV8 engines. Firing order is the same for all and is stamped on the intake manifold.
  4. sdowney717
    May 20, 2004
    375
    Newport News, VA
    Is that the same for all v-8 of any manufacturer?
    I am glad you guys posted. I found this thread and it seems they are saying even's are on the aft right side
    but really they are on the aft left side.?
    left right front back all depends on where your looking and sitting. I would have misread it and got it reversed.
    Passenger rear is number 8?
    http://www.binderplanet.com/forums/showthread.php?t=95718
  5. Dennis Bernth
    5,962
    34
    Mill Creek, IN.
    Yep, passenger rear is #8.
  6. Jay Tabor
    Jay Tabor Banned
    Jan 2, 2002
    4,716
    Pahrump, Nevada
    no not the same for all engine manufacturers.
    not all engines are v 8,
    get your self an IH engine manual and all of that info is detailed in it.
    all references to/for a vehicle are referenced from the driver sitting in the car on drivers seat FACING FORWARDS for left and right sides,
    and the proper way is to state 'drivers side' or 'passenger side'
  7. scoutboy74
    4,876
    208
    Unless vantagepoint is otherwise specified like I did in my previous post...onnacounta the fact that I ain't usually sittin' in the driver's seat when I'm pokin' arount underneath the hood.
  8. Greg R
    Greg R Y-Block King
    3,794
    143
    No, Cadillac for example has the driver's side is even numbered and the passenger side is odd with a firing order of 15634278
    Ford 302 is passenger side 1,2,3,4 driver side 5,6,7,8 front to rear with a firing order 15426378
    Ford 351, 400 is the same numbering but a firing order 13726548.
    Even day job mechanics need a book now and then to keep track of all the variations.
  9. jeff campbell
    12,013
    296
    whenever buying parts or discussing motors and or parts,it's usually described as if you were in the drivers seat..drivers side is left,pass., is right.same with body work and or parts.NOT from the front of the vehicle.
    1975IH200 likes this.
  10. scoutboy74
    4,876
    208
    And that makes perfect sense in those situations. I'm not trying to be a contrarian, I get it. My point is that when one is actually looking at the engine and noting cylinder location, one is generally either in front of or off to either side, not behind it. You can't see the engine from the drivers seat unless the hood is removed, and even then not that well. So in this case, why not reference it the way you be looking at it from a practical standpoint?
  11. Eric VanBuren
    May 7, 2004
    6,011
    Maple Valley , Wa
    For every engine I've ever seen the cylinder #1 is always the farthest forward. On V type engines the banks are always offset and the bank that ends up farther forward is has #1 cyl and is the #1 bank. For most engines except Fords the next cyl number is the next farthest forward, ect. So you end up with odd and even banks. Ford on the other hand does as mentioned above.
  12. Bill Bennett
    Bill Bennett High Wheeler
    May 26, 2003
    1,728
    21
    Torrance, CA
    On my 304, the cyls are numbered at the end of the intake manifold runners - about 1" from where they fit to the heads.
