hydro-boost seals found
Discussion in 'Diesel Tech' started by bbellster, Mar 29, 2005.
  1. bbellster
    bbellster Farmall Cub
    Oct 8, 2004
    141
    Lafayette, IN
    I don't want to step on Vanco's toes, but after an extensive search, I finally found a source for the input and output shaft seals for my hydro-boost. It came off of a late 70's GMC 1-ton, but as far as I can tell all the GM units look about the same. Anyway the place is called Elder Rubber 1-800-231-2099. They are located in Texas somewhere. The only bad thing is that you have to buy a min. of 25. Its not as bad as it sounds though, they are only $0.40 each. :D
    You should be able to give them the old Bendix part number on the seal.
    Bendix #_______________ Elder #
    129540 _______________ 9-140
    129484 _______________ 5-19
    I don't know about everyone else, but this sure beats paying $180-$200 for a rebuild, just because the seal leaks.
    Brett
  2. CareyWeber
    3,812
    Ridgeway, SC
    bbellster,
    That is great info.
    Carey
