How do I remove Metro door handle?
Discussion in 'General IH Tech' started by Randall Barringer, Jul 4, 2020.
  1. Randall Barringer
    Mar 4, 2004
    3,721
    854
    baton rouge, louisiana
    I am trying to remove this handle from the door.
    I got the pin out.
    The handle is seized onto the rod.
    Even if I cut the rod, I don't see how the rest comes out...[​IMG]
    Sent from my SM-G955U using Tapatalk
  2. Randall Barringer
    Mar 4, 2004
    3,721
    854
    I got it off using a pickle fork.
    More Metro parts saved and headed to a new home.
    stroker3 likes this.
  3. Randall Barringer
    Mar 4, 2004
    3,721
    854
    So, here are the steps to remove an International Metro door handle and latch:
    1. Grind head off of pin holding inside handle on
    2. Use a punch or small drill bit to hammer out the pin
    3. Place pickle fork between handle and latch and start forcing the handle off. Use the fork all around the handle, not just in one spot. 20200704_152153.jpg 20200704_152135.jpg 20200704_153206.jpg View attachment 177414
    4. Once the handle is off all the mounting screws can be removed and the square rod with outside handle can be pulled out
