High Temperature vacuum Control Valve
Discussion in 'General IH Tech' started by Hutch, May 15, 2006.
  1. Hutch
    Hutch Farmall Cub
    Jan 15, 2004
    343
    AZ/Wyoming
    The shop manual says they are only on AC equipped scouts. My Scout had AC, but I ditched it in favor of OBA and a ragtop :D
    Question: Do I need this valve, or can I just put a plug where it goes and reroute the vacuum tube so it runs from the carb to the vacuum advance on the distributor. The valve was capped prior to me pulling it off to clean up the intake manifold (a piece of vauum tube running out of the valve then right back to it) Did I just answer my own question? :confused:
  2. WilliamEHardy
    WilliamEHardy Farmall Cub
    Aug 24, 2003
    447
    Custer, SD
    You can just cap it - it's used when the temp increases to a predetermined point to advance the timing at idle & thereby increasing RPM's & cooling via increased fan speed. :)
  3. Hutch
    Hutch Farmall Cub
    Jan 15, 2004
    343
    AZ/Wyoming
    Thanks Bill. That's good new because the parts store would have to special order one!
