Help with my sd33
Discussion in '"International" Harvesters' started by Dominik, Mar 26, 2017.
  1. Dominik
    Dominik Farmall Cub
    Mar 26, 2017
    19
    Help please
    Can I blank them off is non turbo want to put this engin in Land Rover defender
  2. jeff campbell
    14,674
    1,183
    do you know what they're for before you cap them off ?
  3. Dominik
    Dominik Farmall Cub
    Mar 26, 2017
    19
    N
    No can u help me
  4. Dominik
    Dominik Farmall Cub
    Mar 26, 2017
    19
    Engine done 30.000 miles really rare to get here
  5. jeff campbell
    14,674
    1,183
    ok, will look in my manual and see what i come up with.
  6. Dominik
    Dominik Farmall Cub
    Mar 26, 2017
    19
    Th
    thank u
  7. jeff campbell
    14,674
    1,183
    my manual doesn't show what they're for. but the upper 1 is near the water jacket, and the lower 1 is near the oil passage's. best i can do for you.
  8. CoopVA
    CoopVA Binder Driver
    Nov 29, 2013
    888
    193
    Linden, VA
    They are both for oil. I believe they are the supply and return for the alternator... I plugged mine as I'm planning on going to hydro boost and not using the stock alternator...
  9. Dominik
    Dominik Farmall Cub
    Mar 26, 2017
    19
    Can I cap them off don't need it for alternator
  10. Dominik
    Dominik Farmall Cub
    Mar 26, 2017
    19
    T
    The bottom one looks really clean inside need to be 100% sure before I cap them both off
  11. CoopVA
    Nov 29, 2013
    888
    193
    Linden, VA
    If you are not going to use them, then yes, you can cap them off.
  12. jeff campbell
    14,674
    1,183
    good job coop, forgot all about the alt !
    CoopVA likes this.
  13. Dominik
    Dominik Farmall Cub
    Mar 26, 2017
    19
  14. jeff campbell
    14,674
    1,183
    your oil holes you asked about
  15. jeff campbell
    14,674
    1,183
    the stock alt is lubed by the engine oil thru them holes in the block.
  16. Dominik
    Dominik Farmall Cub
    Mar 26, 2017
    19
    What I gonna do now ??
    This engine needs to go on my defender
    Need help can I use the engine without the engine ore what can I attach to it every part of this engine is really expensive over here
  17. jeff campbell
    14,674
    1,183
    where are you located at ?
  18. Dominik
    Dominik Farmall Cub
    Mar 26, 2017
    19
    England
  19. Dominik
    Dominik Farmall Cub
    Mar 26, 2017
    19
    I need an speedo cable because there cute it
  20. Dominik
    Dominik Farmall Cub
    Mar 26, 2017
    19
    This is all what I got
