Help with Clutch after adjustment
Discussion in 'General IH Tech' started by Ride5C2, Sep 21, 2019.
  1. Ride5C2
    Ride5C2 Farmall Cub
    Sep 30, 2018
    96
    12
    Central Florida
    T19 4 speed transmission, 345
    I removed the 2' body lift on my scout and disconnected the clutch linkage to do it. Here's what I did to hook it back up:
    1. Adjusted the Rod that actuates the pedal to shorten it
    2. Pedal sits at 9' from the angled floor
    Hooked the clutch link rod and the Pedal actuator rod back up and the clutch has almost no resistance and doesn't engage, I can't figure out how I messed something so simple up . . .
    Any insight would be appreciated. I'm having the Scout blues today.
    Thanks!
  2. winchested
    3,239
    1,188
    My scout with a 1.5" Body lift and new poly body mounts has just enough length on the stock clutch rod for proper adjustment. Id think yours is likely too long. You sure it wasn't cut and had a couple inches added to it? The measurement you're really concerned with is the TOB engagement not the pedal position. The return spring regardless should always put your pedal back to 9" regardless of how the rod is adjusted.
    vince konicki likes this.
  3. 72soa
    72soa Binder Driver
    Oct 23, 2003
    987
    172
    Oak Hill, FL
    Like what was said above. Your clutch rod is too long. It has either been extended or someone put a new one in that was longer.
  4. Ride5C2
    Ride5C2 Farmall Cub
    Sep 30, 2018
    96
    12
    Central Florida
    I think you guys are right. The rod definitely looks to have been welded. Mine measures 17 and 3/4 inches from the bottom of the forks at their lowest setting (end of threads).
    Anyone have one handy to confirm the stock length? If not, I can call my friends at ihparts
    Thanks for the advice!
  5. Ride5C2
    Ride5C2 Farmall Cub
    Sep 30, 2018
    96
    12
    Central Florida
    Circling back on this one. My clutch rod was just over 17' from base of threads. Ordered a NOS one from IHParts and it's 15' at the same measurement. Will install in a week or so and I think I'll be back in business.
  6. 72soa
    72soa Binder Driver
    Oct 23, 2003
    987
    172
    Oak Hill, FL
    Fix the lean before you install and adjust.
  7. Ride5C2
    Ride5C2 Farmall Cub
    Sep 30, 2018
    96
    12
    Central Florida
    Dang, hadn’t thought about that. Will do.
