Flame Arrestor Part #
Discussion in 'General IH Tech' started by kerrmudgeon, Mar 15, 2005.
  1. kerrmudgeon
    kerrmudgeon Farmall Cub
    Apr 15, 2003
    Texas
    Hi fellow enthusiasts,
    Does any body have the part # for the flame arrestor ? I have been to all the parts store's (Napa, Auto Zone, O'Reillys, etc) and when I ask for the part, the most common reply is "O"Sh@#%t :rolleyes: . Never heard of that. Whats it for? Whats it do? :confused: My reply is I don't know but I want two of them for a IH 392 :(
  2. JWaters
    JWaters Binder Driver
    Jan 22, 2002
    517
    Tampa Bay, FL
    I have an unverified number,
    Standard #V-115
    I put it in my list but I have never tried to buy it
    Jason
  3. Ike T
    Ike T High Wheeler
    Dec 23, 2004
    1,264
    Augusta, GA
    I found this part number in a search last week: 400858C1.
    All the local chain stores here said they couldn't order it, so I called a light line dealer. I was told that any International Dealer should have them in stock, but I have not verified this. (Oh, and the light line dealer did have one and shipped it to me.) Maybe we should add this number to the useful part number listing? :)
    Hope this helps,
    Tim
  4. Munchies
    Munchies High Wheeler
    Oct 19, 2003
    1,462
    Heidelberg, Germany
    You only use one flame arresotr. The other fitting on the back of the engine is a PCV valve. Dont mix them up!
  5. Russ McLean
    Russ McLean High Wheeler
    Oct 12, 2001
    1,366
    Hereford, AZ
    Re: Flame Arrestor Part # --> Bad information
    I have owned 2 other variants.
    1. No PCV fitting in valley pan. PCV screwed into one valve cover, flame arrestor screwed into the other valve cover. Non IC 392 in 1971 1210 pickup. Quite certain this is stock, this configuration was shown in the MT-124 parts manual.
    2. PCV in valley pan, flame arrestors screwed into both valve covers. IC 392 out of a T'all, currently in Marian's Scout II. Quite certain this is stock, the air cleaner has 2 opposed hose fittings for the flame arrestors.
    I "suspect" that these changes came with the introduction of the IC-392 and the 727 tranny in the full sized Light Line.
    Russ
  6. John in KC
    John in KC Binder Driver
    Apr 7, 2004
    601
    DIVIDE, CO
    Unless you lost yours you should not need to get a new one, they can be cleaned and reused. I took mine and cleaned it out with gas, reinstalled it and was on my way.
    Thanks,
  7. rlireland
    Sep 8, 2003
    4,476
    Tucson, AZ
    I'm reviving this thread with some questions about PCV valves and flame arrestors.
    Is the flame arrestor supposed to rattle like the PCV valve? If not, how do you know if it's in working condition or not.
    The flame arrestor is plumbed to the carburetor air filter housing and the PCV valve is plumbed to the intake manifold. Correct?
    The flame arrestor part number in post #2 is correct. The PCV valve p/n is 379316C1.
    Roy
  8. scoutboy74
    6,740
    1,171
    There are no moving parts in the arrestor, so there is nothing to rattle like the PCV. It's basically steel wool that can be blasted with solvent and compressed air over and over again. Correct on the plumbing.
  9. rlireland
    Sep 8, 2003
    4,476
    Tucson, AZ
    Thanks!
    Roy
  10. mallen
    mallen Y-Block King
    3,763
    970
