fixing brown coolant, what else while I'm here..
Discussion in 'General IH Tech' started by damonwill, May 10, 2015.
  1. damonwill
    damonwill Binder Driver
    Jan 1, 2014
    518
    110
    Austin, TX
    So I've been having a coolant leak from under my intake manifold for a while now and decided it was time to fix it. So I pulled off the intake. And the valve covers and the valley pan. I figured I might as well replace those seals while I'm at it. And so I pulled the radiator to clean it and the water pump to replace it. The pump blades were pretty corroded.
    It looks like one of the welch seals is leaking from the intake, so I'm going to replace all of those.. I'm going to clean and paint all the pulled parts. Oh, and I'll install new coolant hoses and seals for the metal pipes. So, my question is what else should I replace/reseal while I'm at it? any upgrades you'd recommend? I don't care about keeping her stock.
    Any advice on doing the welch seals? first time doing those...
  2. Mark Aycock
    Mark Aycock High Wheeler
    Jun 3, 2004
    1,452
    204
    Houston,Texas
    Don't forget the heater hoses.
  3. mudhog
    mudhog Farmall Cub
    Dec 14, 2011
    56
    Mc Neil, AR
    I replaced all vacuum hoses and front main seal when
    I had my intake and water pump off. Front seal was leaking pretty bad.
  4. damonwill
    Jan 1, 2014
    518
    110
    Austin, TX
    Already got the heater hoses. and I'll have to look into how to replace the main seal... I'm also looking into using Evans waterless coolant. Have to do more research...
  5. wjajr
    wjajr Binder Driver
    Apr 4, 2015
    603
    91
    Eddington
    Rusty coolant is a result of rusty water jacket most likely caused by someone running straight water in cooling system.
    You should flush water jacket using a commercial flush which will remove some rust if engine and head are still installed in truck. Rust incrusted water jacket will impede heat transfer between metal of block and head to coolant reducing system's ability to rid excess heat via radiator.
    Once engine is as clean as one can get it, refill with 50-50 mix anti freeze water mix of which has anti corrosion and water pump lubricating properties, and correct thermostat and pressure rated radiator cap.
    My 2 cents:
    I would be reluctant to use Evens Waterless Coolant without first a good hot tank dipping of block and head to fully remove all rust scale.
  6. damonwill
    Jan 1, 2014
    518
    110
    Austin, TX
    Prob a negative on the hot dip. Not in the budget. but i'm going to pull all the welch and high pressure clean inside and out. I've always had a 50/50 mix and always had brown eventually. I think the evans will resolve that. but yes, I need it as clean as possible.. I wonder if I put a filter on the heater hose to pick up any residual crude that breaks free later... It would have to be a filter rated at 200F or more....
  7. damonwill
    Jan 1, 2014
    518
    110
    Austin, TX
    I'm in the process of removing the intake welch plugs and freeze plugs and I can upon an issue. The front passenger side freeze plug seems to be partially blocked by something...
    What is it? And how do I remove it to change out the freeze plug?? I tried turning, pulling, pushing it. No movement..
  8. blue smoke
    blue smoke High Wheeler
    Sep 28, 2008
    1,267
    58
    Melissa Texas
    That I believe is the plug for the dipstick tube. IH used the same cover for s-v engines so if an engine was going into a Loadstar it would use the front for a Scout the side
  9. damonwill
    Jan 1, 2014
    518
    110
    Austin, TX
    You are correct sir!! A couple taps and it popped out.
    Thanks!!
  10. wjajr
    wjajr Binder Driver
    Apr 4, 2015
    603
    91
    Eddington
    That has been done before.
    I'll check and see if I can't find how it was done.
    Look here, and here.
  11. damonwill
    Jan 1, 2014
    518
    110
    Austin, TX
    I'm thinking more like this:
    Coolant Filter Kit
    I can put on the heater lines. Then just keep the heater valve open to slowly filter anything in the coolant... and if it get clogged up and takes me a little while to replace the filter, no big deal since its on the heater side. the main coolant loop will be unaffected...
  12. Doc Stewart
    35
    Leave the thermostat out untill it is as clean as you want it.
  13. damonwill
    Jan 1, 2014
    518
    110
    Austin, TX
    actually, that brings me to a good question. I'm in south Texas where is rarely get cold enough to justify a thermostat. I usually remove the thermostat from all my vehicles and have never had a problem. Now, I've heard a couple posters say that the thermostat is critical to "balancing the flow of the coolant system" and "it was engineered to have a thermostat". I've run my scout for the last 6 months without a thermostat and she's always between 160 and 180 F. the electric fan turns on at 175 and off at 165. so should I just leave the thermostat out for good? I prefer to if possible...
  14. kevingweq
    kevingweq Y-Block King
    Nov 1, 2013
    3,006
    640
    Sudbury Mass
    The thermostat is just as important to keep the engine warm as it is cool , Engines are designed to come up to a somewhat optimal temperature 180 deg and not fluctuate too much.
    The clearances on pistons,cylinders, valve guides etc, are designed to perform correctly at the correct "warm" clearances , Too much temperature variation either way is hazardous to engine lifespan .
  15. Ruper22
    Ruper22 Farmall Cub
    Sep 7, 2009
    Chesapeake, VA
    Hey I need one of the plugs to block off a front dipstick. Right now I'm running 2 dipsticks cause I had to fill that hole for the one in the block.
    Are any acailable and where?
    Maybe a small freeze/expansion plug would be perfect.
  16. Ruper22
    Ruper22 Farmall Cub
    Sep 7, 2009
    Chesapeake, VA
    Pops it is a 196 four banger. 1967 date of manuf.
