Exhaust Manifold to Exhaust Pipe Connection
Discussion in 'General IH Tech' started by Chris Breedlove, Oct 4, 2018.
  1. Chris Breedlove
    Chris Breedlove Farmall Cub
    Sep 11, 2014
    105
    Canton, MA
    Hi there, need help on where to find the exhaust flanges to hookup the exhaust manifold to exhaust pipe. Going from headers back to cast manifolds. It's the flange that uses the donut gasket. Part number and source? Thanks!
  2. MrKenmore
    MrKenmore Dreams of Cub Cadets
    4,059
    1,671
    The flange is loose. The exhaust shop would make the bell end on the pipe that would receive the exhaust donut. The loose flange brings the bell end (cause the bell end is bigger than the loose flange now) against the donut.
  3. winchested
    3,936
    1,532
    OE was a steel donut 2.25"
    Guys on here are running federal 60556 gasket donut. I've bought these to try.
  4. RinTX
    2,535
    921
    If I read OP right he is looking for a source for the flange...
    Chris Breedlove likes this.
  5. walkersscout
    walkersscout High Wheeler
    Oct 5, 2005
    1,613
    276
    AZ
    Any of the vendors should be able to get you a couple.
    One thing to consider is adding a flex joint a few feet away from the head pipe. It will greatly assist in avoiding leaks at the donut, as well as broken exhaust manifold flanges. Helps the donuts last a lot longer two. I bought mine on ebay for about $15 or so.
  6. jeff campbell
    15,822
    1,720
    They usually come on the Y pipes. Early'80's dodge omni gasket is by far better than OE.it won't break.it forms to manifold.
  7. Chris Breedlove
    Sep 11, 2014
    105
    Canton, MA
    C
    O
    Correct. Thank you. Yes, I'm looking for a brand, part number for the exhaust pipe flange hookup to the exhaust manifold.
  8. jeff campbell
    15,822
    1,720
    Are you looking for 1 or a pair ? Cast iron 1 thats about 1" thick ?
  9. jeff campbell
    15,822
    1,720
    Here's part # 217 911 R1. Pic'all's & S2's use these.for SV8's
  10. MrKenmore
    4,059
    1,671
    Any exhaust shop would have these.
  11. RinTX
    2,535
    921
  12. MrKenmore
    4,059
    1,671
    There you go. Remember you don't a weld style. It's loosey goosey around the pipe. Then gets snugged around the donut.
  13. MrKenmore
    4,059
    1,671
    Bolt spread is 2 3/8" center to center by the way.
  14. Chris Breedlove
    Sep 11, 2014
    105
    Canton, MA
    Thanks everyone. Found a local part with the part number provided. Thanks!
