Elbow ELIMINATED!
Discussion in 'Diesel Tech' started by nikbristow, Nov 19, 2006.
  1. nikbristow
    nikbristow Farmall Cub
    Jul 29, 2006
    55
    Austin, TX
    Well, as of about an hour ago my elbow is long gone and sitting in my front yard. :D
    Bought the stainless steel EE and S-pipe from Sergio here on the BB. Looks good. Sounds freaking demonic. Gonna try to get 3" exhaust welded on next week but probably gonna be driving home to Kansas on Wednesday with just the header. :eek: :D
    Any good suggestions on a muffler that won't be too loud but still allow good flow? I live in a part of town where the poodles drink lattes and my morning start-up cloud is already reason enough for my neighbors to show up at my door with torches and pitchforks :D
    Haven't run it through the seat-of-the-pants dyno yet. But I'm about to go climb a hill I drive up between me and work and see how she does.
    When I get back it's installation of the guardian angel that is the pyrometer.
  2. zen
    zen Farmall Cub
    Mar 9, 2006
    344
    london
    you dont need a muffler...i live in central london..i don't get any looks when i drive past the police or peoples..unless using lots of right foot(different then :D ..or they are petrol/diesel heads)..at tick over or low load its real quiet..you just get the turbo whistle..
    it also passes gov yearly test like it no probs..
  3. sergio chav
    sergio chav Farmall Cub
    Jul 21, 2004
    149
    norwalk,ca
    Nik,
    forget the muffler,it's not that loud if you run your exhaust all the way back like the stock pipe.I use a Borla 3" staight thru muffler 12' long x 6" dia. it quieted down a bit.
    Sergio.
  4. Carl Wiese
    Nov 14, 2001
    8,169
    50
    Oregon City, OR
    No muffler needed. I lost mine when I went three inch and a days hasn't gone by when I have wished I had it. All the muffler is going to do is rob your power and keep more heat in the turbo and cylinders.
  5. nikbristow
    Jul 29, 2006
    55
    Austin, TX
    Okay, counting the search I did, that's 54 million votes for a straight pipe, zero for a muffler. I guess that's settled.
    As far as the s.o.t.p. dyno, wow! Torque didn't seem to be that different, but the top end, when the turbo is really whining (and quite audibly I might add), the thing takes off like it never has. I'm a believer.
    This an official recommendation for Sergio's EE and S-pipe. The thing is awesome and he's been real helpful as far as customer service. $400 for the EE and stainless steel s-pipe plus copper anti-seize, gasket and all the hardware including new exhaust studs. For a fella with no fab experience and little time to source parts it's worth it in my book.
    I will add this technical advice. I'm sure it's a "duh" for all you experts, but for the next **** it may prove useful. Those exhaust studs can be a real bear, but don't give up. A metric crap-ton of Liquid wrench, an appropriate amount of cursing and a prayer to the diety of your choice and they'll break loose. ;)
  6. IH64Scout
    Apr 13, 2004
    4,683
    Jessup,PA
    $400!!! :eek: that's a bit steep for a little round piece of metal! plus the $150-200 to get the exhaust run. :( man i'm gonna have to save quite a bit this winter.
  7. sergio chav
    Jul 21, 2004
    149
    norwalk,ca
    Nik,
    If you want a bit more performance on the bottom end you should replace your turbine housing with a mecedes one and set boost to 8-9 psi.This should really wake-up your sd33t.
    Thanks for the review.....Glad to be of help.
    Sergio
  8. BinderMark
    BinderMark Farmall Cub
    Mar 20, 2003
    67
    Louisburg, KS.
    Did you happen to take pictures of the purchased EE before installation? We could see some after installation pictures also, if you were so inclined to take some.
    Thanks,
    Mark
  9. zen
    zen Farmall Cub
    Mar 9, 2006
    344
    london
    so whats the standard ar of the sd33t then and the mercedes one??
    i have fitted gt2052 which has .48 on both compressor and turbine..i think its abit small..
  10. JordanP
    JordanP Farmall Cub
    Oct 12, 2004
    182
    Kernersville, NC
    the standard scout sd33t exhaust housing is a .62 ratio and the M-B housing is .48
    I too think that its a bit small, but its better than the stock .62 housing
    Ideally, a .53 (if there was one) would be about perfect i believe
  11. zen
    zen Farmall Cub
    Mar 9, 2006
    344
    london
    and the compressor side?? i am now looking for a 0.62 to replace the 0.48...lack of power above 3000rpm(but thats 80mph+)
  12. Shoehorn
    Shoehorn Binder Driver
    Sep 3, 2006
    608
    Clifton, IL
    While it sounds nice, and gives better off idle response, opening up the exhaust on a low rpm international motor is not good overall. A free flowing exhaust will increase HP only in the regions of the tach where you shouldn't be to begin with, and will decrease low end torque. You will also need to adjust your carb or possibly use a higher CFM carb. Opening up your exhaust will cause you to run lean and hot without carb adjustment.
    At the end of the day, it's really all about what makes you happy. If you are happy, that's good enough. From a technical standpoint, though, you want back pressure.
  13. Shoehorn
    Sep 3, 2006
    608
    Clifton, IL
    Not all of what I just said applies. It completely slipped my mind that I was replying to a post in "DieselTalk". The basic principles are still accurate. I was thinking gas when I wrote it though.
  14. JordanP
    JordanP Farmall Cub
    Oct 12, 2004
    182
    Kernersville, NC
    Actually the basic principles are NOT accurate, they are completely different. A diesel wants as little back pressure and restriction as possible. Sort of like a forced induction engine, but even more so. Id be willing to say that you could have no downtube whatsoever and let the exhaust exit directly out of the turbo and it wouldnt hurt the way the truck runs at all...and if it werent for the dirty engine bay Id have, Id consider that.
  15. NW 4x4
    NW 4x4 Farmall Cub
    Sep 7, 2006
    Traverse City, MI
    You need little to no back pressure after the turbo. For an n/a diesel you want a tuned exhust, just like a gasser.
    clark
