Diesel Mileage with Other Engines
Discussion in 'Diesel Tech' started by Alpine, Jan 7, 2017.
  1. Alpine
    Alpine Farmall Cub
    May 12, 2016
    I currently have a sd33na/727/3.73's with 33's . I have been kicking around the idea of upgrading to a SD33T/T19/D300 package. But I have also been looking into a swap to a different make package. Possibly a GM 6.5 turbo diesel.
    What have those of you that opted to replace the SD with a 7.3, 6.2, 6.5, 4BT, ect... Seen for mileage? Did you go with an auto trans or manual?
    Thanks in advance.
  2. dan1500
    dan1500 Binder Driver
    Apr 12, 2003
    604
    65
    Fort Wayne, IN
    I had a 6.2L with Banks turbo and GM Overdrive trans in a Traveler. It averaged 17.5 mpg over the time I had it. I think I was probably lugging it because it still had the original 3.07 axle ratio. It would cruise in overdrive around 1000 rpm. In this case going to a higher ratio probably would have improved things.
  3. Sammy
    Sammy Y-Block King
    Oct 22, 2001
    3,066
    412
    Grigsby's Bluff, TX
    The junk in my signature. Haven't driven it yet. Expecting at least 20 mpg (same as SD I had) but with a touch of power.
    I had the 33T, T19, Dana 300 at one time. Ended up pulling the Dana 300 in favor of a Spicer 19 with a saturn overdrive and may have got .5 mpg better than before. Just an experiment that just didn't net the mileage increase that I was after but the four levers sticking thru the floor was an instant theft deterrent.
    dooley.pula likes this.
  4. Alpine
    Alpine Farmall Cub
    May 12, 2016
    What are putting in it?
  5. polvo
    polvo Farmall Cub
    Nov 11, 2014
    102
    St. Louis
    I have a 4bt that I was going to put in a travelette. After looking/researching at a lot of options I thought it would be the best choice because it was not as large as others, but makes very good power and can be tuned to be really efficient. Also parts a very accessible. An Isuzu 4BD1T is also a very good choice. It is actually smoother than the 4BT, but parts can be somewhat hard to come by.
  6. bindermike
    bindermike Farmall Cub
    Apr 6, 2003
    253
    Lorton, VA
    I average about 25 mpg on the highway at a little more than 70 mph. 3.73 rear gears; 235/85-16 tires; and the ZF6-650 six-speed trans. I'm looking to go to 3.54 rear gears to bring my rpm down a touch; it may increase the highway mileage too.
    My nephew put a 4BT in his 78 Terra, with a NV4500 trans. I don't know what kind of mileage he gets though.
    Good luck with your project, Mike
  7. Alpine
    Alpine Farmall Cub
    May 12, 2016
    Now my wheels are spinning. A friend told me he would sell me a 4.8L with a 5 speed and t case for $500 with all the wiring. It would probably be a good fit for the traveler but since it came with a diesel I wanted to stay with one.
    That thought got me thinking and researching. It looks like the NV3500 and NV4500 share the same bolt pattern. Has any one put a NV3500 behind their SD?
  8. Joe S
    Joe S Farmall Cub
    Oct 27, 2011
    218
    Sunland, Lompoc, CA
    I thought the 3500 had an integral bell housing.
  9. Alpine
    Alpine Farmall Cub
    May 12, 2016
    It is. From what I have read it has the same engine mounting bolt pattern as the nv4500. I have not had time to look up what the adapter kit looks like for the nv4500. I'm hoping to have a chance to look more into this tomorrow.
  10. Joe S
    Joe S Farmall Cub
    Oct 27, 2011
    218
    Sunland, Lompoc, CA
    The NV4500 has no bell housing. I had to make one to mate up to the SD.
  11. Alpine
    Alpine Farmall Cub
    May 12, 2016
    Do you still have a template? How exactly did you do it? Flywheel spacer as well as a bell housing adapter? Any pics?
  12. Joe S
    Joe S Farmall Cub
    Oct 27, 2011
    218
    Sunland, Lompoc, CA
    I made a wood pattern and had it cast. Then machined on Tuesday nights at Glendale College. I had been going there off and on for years and was on good terms with the Instructor. He let me leave it set up for a few weeks while I worked on it. This was on an old 24" LeBlonde. All the kids wanted to use the fancy new machines so there was no conflict.
    I'll have to find some pics. I thought I posted some on the full size Jeep site but they are all of the suspension.
  13. steve graham
    steve graham Farmall Cub
    Nov 19, 2001
    419
    24
    Willcox Arizona
    I've been running and improving the performance of the 4BTA in my Scout for 16 years.
    In town low 20's. On the freeway unladen 65-70mph high 20's. In 2015 towed my 19' Casita RV (3500 lbs) up to RMIHR and back, averaged 18 mpg. All of this driving is done with the AC on, always hot in AZ.
  14. Alpine
    Alpine Farmall Cub
    May 12, 2016
    What trans are you running and gear ratio? Tire size?
  15. steve graham
    Nov 19, 2001
    419
    24
    Willcox Arizona
    See my signature, it's current.
  16. Alpine
    Alpine Farmall Cub
    May 12, 2016
    Your signature was not visible on my phone yesterday, even when I was logged in. I see it today on the computer. Thanks
    When you purchased your engine, was it in a truck or did you buy the engine separate? If it was in a truck, what was it in? I have heard it is common to see the 4bt's in GM bread trucks. I haven't had any luck locating one yet. I also heard it is usually cheaper to buy the entire truck than just the engine.
  17. walkersscout
    walkersscout High Wheeler
    Oct 5, 2005
    1,578
    263
    AZ
    Steve's is a pretty nice conversion and runs well. He would be a good one to look at as far as a how to.
    steve graham likes this.
  18. steve graham
    Nov 19, 2001
    419
    24
    Willcox Arizona
    I purchased my first engine, with a VE pump sight unseen from a recycling yard in Georgia, $2500 shipped to AZ. It came out of a Frito Lay P30 chevy box van. Last engine I bought local was a 130 hp P pump out of a Frightliner MT35 box van, $3500. You probably can beat those prices but you'll have to dismantle the van. Drive the van home and you know you have a good engine.
  19. Joe S
    Joe S Farmall Cub
    Oct 27, 2011
    218
    Sunland, Lompoc, CA
    Some pichers of my NV4500 bell housing. Sorry it took so long. Not much to see except the last one. That's the clutch arm with a dust boot I made out of a leather glove.
    Nothing special on the crank end. Might have had to find a bearing with the correct OD and ID but I don't remember an issue. Was around the turn of the century, though.
  20. Alpine
    Alpine Farmall Cub
    May 12, 2016
    Thanks for the pics. I am leaning this way as well.
