couple basic questions
Discussion in 'General IH Tech' started by Scott80, Apr 15, 2019.
  1. Scott80
    Scott80 Farmall Cub
    Mar 6, 2019
    Have some rookie questions for you veterans
    1.Shocks: if my current shocks at resting position measure 15 inches can I add a total of 3 more inches (1.5 up and 1.5 down) when purchasing new ones for overall size? I was asked what compressed and open measurements where so I assumed that 1.5-inch travel would be appropriate.
    I was also told that bilstein 5125 over 5100 for scout 80, suggestions?
    2.Gas mileage: should I be burning through 7 gallons for a 70-mile trip? Considering the age I know the smell of gas is common but should it be bothersome when driving?
    3.Would a one-inch spacer on the rear and front cause to much stress on the bearings? Can’t do the lift route so want a small bump out.
    4.Clutch/synchros: While driving I need to wait for the RPMs to settle down when shifting from one gear to the next. If I try and switch gears fast with little loss in RPMs I grind. 1 to 2 is ok but if I wait to long for 2 to 3 the truck seems to bog down a bit because I have lost power. How do i check my trans fluid?
    I attached three photos and if someone can please identify them for me
    scout misc 1: whats it purpose and does in need to be through the hole. If i cant bend it, can i add extension?
    scout misc 2:seems to be leaking. name and function, seal or whole unit
    scout misc 3: tester points to an open valve, should it be left alone and whats it purpose? On the engine below the throttle there is a 9 degree thread into the engine with a cap on the nipple. that normal or should it go with the exposed valve?
    scout misc 4: master is new and whats the other? seems to be leaking
    Thanks for the help
  2. Scoutcamper
    Scoutcamper Farmall Cub
    May 23, 2018
    272
    100
    Phoenix, AZ
    What vehicle / year / motor? I'm guessing early Scout 80 with 152 4cyl?
    I don't feel qualified enough to answer the suspension or mileage questions...
    What transmission do you have? First gear might not have a synchro.
    I'm going to take a stab at the pics, going from general knowledge and not that familiar with the early motors... I'll try to check back and correct myself if nobody else jumps in:
    scoutmisc1 I'm guessing oil vent / blow-by tube. Lots of earlier vehicles had a tube to vent crankcase pressure directly to outside the motor / down at the road, before emissions requirements made PVC systems that recycled crankcase fumes to the intake mandatory.
    scoutmisc2 is the fuel pump, leak seems to be from the mounting surface? I'm guessing a new gasket might solve it, might need new gasket on the engine side cover / tappet cover as well.
    scoutmisc3 I'm guessing is the vacuum feed to the wipers
    scoutmisc4 is the brake master cylinder (top) and clutch master cylinder (bottom)
    Hope this helps!
    -Josh
    stroker3 likes this.
  3. mallen
    mallen High Wheeler
    2,130
    287
    10mpg seems to be a bit on the low side. Id bet the smell of gas is connected to the low mileage, that is, gas is leaving the vehicle unburned. Is the smell coming from the exhaust pipe? If not, then it seems you may have a leak. If it IS coming from the exhaust, then check wires and plugs. Make sure the timing and dwell (if you have points) are set right. Check the air filter. Make sure there are not internal leaks in the carburetor. (for example, a dirty needle valve or maladjusted float can cause the float bowl to overflow and dump fuel in the intake. (If its not to bad, the vehicle can still run, but poorly) Also check that the choke is opened when the vehicle is warmed up if you have an automatic choke, or that it opens and closes properly with the choke control if you have a manual choke. Another thing to check is compression.
    Aside from the gas smell, if your having transmission issues and cant shift smoothly or at the right speeds, that can also negatively impact your mileage. (there may be several causes) What gearing are you running in the rear end? The gearing can affect your mileage as well.
  4. Scott80
    Scott80 Farmall Cub
    Mar 6, 2019
    yes 152 3 speed
    t14 trans
    4.27 gear ratio
    gas smell is in the cabin while driving, not so much at idle
    I have to old oil bath filter
    I have an electric fuel pump now, can I block that off?
    I have to look into those issues mallen.
    thanks to both of you guys so far
  5. Patrick Morris
    Patrick Morris Dreams of Cub Cadets
    4,867
    414
    I am not sure there is any real difference between the 5100 and 5125. I think all the 51xx shocks have the same piston and valving type. All that really matters is the max and min length (extended and compressed length), and the damping plate configuration. Most people who go with Bilstein 51xx shocks in their Scouts get the 255/70 valving. Those numbers actually do mean something. If you want to know I can point you where to read about it. Basically it means a fair amount of rebound damping and a bit lighter compression damping. It will give you a 'sporty' ride and is very well suited for the pavement. You could go with the 170/60 valving. The ride will be cushier overall, but also a little bouncier if the road surface gets uneven.
    Regarding the travel you mention, your suspension must have more than just 3" of travel. It would be safer to assume around 6" of travel. (My Scout's front suspension has 10" travel shocks, but it's lifted a bit.) You don't want to drive into something harsh one day bottom out your shocks!
  6. Patrick Morris
    4,867
    414
    To clarify the shock length question. If as you say, your shock's "resting" length when mounted is 15", you probably want a shock with a min length of around 12" and an extended length of about 18" or better.
    And upward (compression) travel of the suspension can be controlled with bump stops. The bigger/taller they are, the sooner they contact the axle and begin absorbing the movement.
  7. Patrick Morris
    4,867
    414
    Regarding your transmission, says on Novak's site that it's fully synchronized with helically cut gears. And it was used in a LOT of Jeep CJs. So it should shift much better than yours does.
    http://www.novak-adapt.com/knowledge/transmissions/manual/t14
    Novak says it was introduced in '67 for the Jeeps. What year is your Scout again?
    You check the fluid level as you fill the transmission. There should be two plugs on its right side. The lower one is for draining, the other is for filling. The image below that I grabbed off ebay shows what they look like. So once you drain the old oil, you reinstall the drain plug, remove the Fill plug and (using a hose dealy) pump in new oil/fluid until it begins running out that hole. This is how you fill your transmission to the proper level. It can be a messy process so have a drip pan and rags handy. Then of course, install the fill plug.
    So you could just remove the fill plug and see if it takes oil. But seeing how this Scout is new to you and lord knows what kind of oil was used earlier by the prev owner and how long ago, you may as well just drain it and refill with the right stuff. It should take a GL4 transmission oil formulated for syncro transmissions, but many people get by quite well using thicker grade motor oils. like straight 50wt. Do some research here on the board if you want. But be warned, oil threads are numerous and get be long, rambly, and heated.
    Scott80 likes this.
  8. Darrel
    Darrel Y-Block King
    3,858
    589
    Scott80 likes this.
  9. Scott80
    Scott80 Farmall Cub
    Mar 6, 2019
    photo attached
    I dont mind but Im even more confused now about wheels. I have 3.75 back space and have gotten the rubbing gone. If I go with a 30 inch bf all ter tire what spacing should I be looking for. I just want a slight bump out
    great resources both of you, thank you!
  10. Patrick Morris
    4,867
    414
    I'm not sure what is confusing to you. I believe he's just saying that if you want the wheels out a little farther, get wheels that are made that way. Spacers can create a weak link between your wheels and your hubs. I mentioned spacers to you as one option, but I was thinking at the time more like 1/2" spacers. And even those would probably require longer wheel studs. Longer probably means more prone to failure over the long haul.
  11. Greg R
    Greg R Dreams of Cub Cadets
    4,664
    471
    I'll tackle your questions: 1) the "pipe" is the crankcase breather or road draft tube. They do tend to drip. I noticed the optional skid pan under the engine and I wouldn't force the pipe to the hole. Let it be for now. 2) the leak seems to originate from the fuel pump mounting flange. Maybe the bolts are loose. Maybe you need a gasket. 3) those are connections to the fuel pump's vacuum pump. It is used or needed for good vacuum wiper operation. What are the wipers running on now? Cap the connections for now to keep the dirt out. 4) the new master cylinder is for the clutch. The leaky one is for the brakes. It appears it's just the cap that is seeping. Maybe the master is overfilled or the gasket in the cap is missing. If the brakes are OK, just tidy up the cap.
    Overall you seem to have a very early Scout. When you need information it is good for us to know the year/model and any information such as engine, transmission, chassis number, etc.
    No wheel spacers. It's a very sketchy set up. 30" tires are about the max for a stock suspension/rig that gives good road manners and no rubbing. It is very close to stock and should work fine. For shocks in 2002 I went with Rancho RS5000 shocks. They have been good for me with good trail and road manners.
    Scott80 likes this.
  12. Scoutcamper
    May 23, 2018
    272
    100
    Phoenix, AZ
    Also just noticed in the scout misc 2 pic that it looks like you have a sharp kink in the hard line coming out of the brass fitting on the lower right side of the pic. I'm guessing this is feeding either your oil-bath air filter or your oil pressure gauge. If you have low oil pressure showing on your gauge that would explain it.
    -Josh
  13. Heyyouguys
    Heyyouguys Farmall Cub
    Sep 3, 2018
    262
    76
    Washington State
    My previous owner added spacers and I about lost a front wheel. 2-3 broken studs and lots of terrifying thoughts! Do a lot of research before using them!
    oneof3k likes this.
  14. winchested
    winchested High Wheeler
    2,273
    648
    I would never run spacers on 40+ year old studs. I've replaced all my lug studs with brand new dormans. Running 1.5" spacers. As long as you properly torque your spacers the same as a wheel there is absolutely no difference in a spacer bolted to a hub than a wheel bolted to a hub.
    Every dually on the road is running spacers bolted to the hubs...
    Sent from my SM-G870W using Tapatalk
  15. 1975IH200
    1975IH200 High Wheeler
    2,756
    260
    My truck is a dually and does not have spacers. Never had spacers. It has proper dually wheels.
  16. Scott80
    Scott80 Farmall Cub
    Mar 6, 2019
    The first post I started was about lift and power of the four cylinder. Since I was at 3.75 backspace 4 was not advised. Should I be looking for 2 inch or even zero to get the wider appearance?
    ordered new gasket, but since i have an electric fuel pump, can I cap this off with a new gasket and plate?
    The wipers work well coming down off the top of the windshield but I need to push the button back in to have them retract back up. I should cap the open valve stem and or switch the rubber tube?
    62, 152 scout 80 3 speed
    Best way to measure current shocks is pull them? what if the wrong ones were installed from the start?
    Next time in I will note resting and driving. what numbers should i be near that are correct for oil pressure?
    Thank you all for responses
    Any link on the forum with photos how to remove the trans? Have a new trans rebuild kit and synchros that I will be attempting in 2 weeks time
  17. Patrick Morris
    4,867
    414
    I'd have to go back and read the other post, but "not advised" may have meant that if you're at 3.75" BS wheels now, then 4" will just do the opposite of what you want, by 1/4". If you can find wheels with 2" backspacing (let's just forget about 0" B.S. as that would be ridiculous), that would push your tires out by 1.75" on each side. But it might drive funny, want to wander and follow the grooves in the road and dart to one side or the other with little warning.
    Another very expensive option then would be go swap in wider axles. Jeep Wagoneer axles, I've read, are a little wider than Scout II axles. You'd get front disk brakes out of that deal.... though you would need to upgrade the entire brake system to make it work.
    A third oddball option would be to stick with the 3.75" backspacing, but on 10" wheels. Then you could maybe run biggish 60-series tires. If you could find suitable tires in that size.
    Well, that would certainly get you accurate max and min measurements on your current shocks. And those numbers will tell you if they give you a comfortable margin for compression and rebound of your springs/suspension.
  18. T-Willie
    T-Willie Farmall Cub
    Mar 20, 2019
    77
    Temecula CA
    Be careful with an electric fuel pump in these old motors. The carb is set for low fuel pressure. That electric fuel pump may be dumping too much fuel unless you got a low flow or adjustable fuel pump. That may be part of two issues your having. Smell of gas could he excess fuel being pushed through the carb and thus the strong smell of gasoline in the cab.
  19. Patrick Morris
    4,867
    414
    ^^^ Presumably it's a FP designed to work with a carburetor, or the Scout wouldn't even be driveable. Very common type. Low pressure, like 3-8 PSI, depending on the FP brand and model. If excess gas were 'pushing through the carb', again, I don't think the engine could run, at least not very well. Sounds like Scott's Scout is at least fairly driveable.
    The gas smell issue needs to be explored though. Is it stronger under the hood? Maybe pop the hood while it's running and check that out.
    What kind of fuel lines are used to get the gas from the tank to the pump? And from the pump to the filter (should be one inline)? and from the filter to the carb? The ends should be checked for cracking around the hose clamps. Check the carb itself for leaks.
    In theory, yes. It depends on how much you trust your electric pump. Do you know its make and model, and how old it is? And do you have sufficient filtering before and after the FP?
  20. Scott80
    Scott80 Farmall Cub
    Mar 6, 2019
    One filter after the pump
    Never smells when sitting only while driving. I feel like its worse when going from 2-3. I do have to wait a bit for the rpms to come down from 2 into 3 then it bogs down a bit .takes time to get into cruising speed in third gear
    Scoutcamper likes this.
