CN5-33 Pump Output in mm3 or CCs?
Discussion in 'Diesel Tech' started by BinderBookie, Nov 30, 2017.
  1. BinderBookie
    BinderBookie High Wheeler
    Apr 25, 2014
    1,298
    267
    A Farm in Ohio
    Doing a story on a transplanted Chrysler-Nissan diesel CN6-33, once in a Scout, for a well known diesel magazine. For the life of me, I can't find the pump output in any books I have or can find online. The tag on the Kiki pump says "240cc" but that can't be the per plunger output on such a small engine. Unless it's 40cc per plunger?? It's an NA engine built in 1975, rated at 89 hp, and it was originally installed in an IH test Scout when they were working up the Scout diesel idea. It's no longer in a Scout, however. I'm hoping one of you might have those specs at hand. Also, if someone has the turbo spec, I could use it to compare-contrast. Can't find it either.
  2. Joe S
    Joe S Farmall Cub
    Oct 27, 2011
    165
    Sunland, Lompoc, CA
    I've got the book for the '80 SD33T put out by IH.
    Doesn't have a "plunger output Spec" but it has a table "Injection Volume Adjustment" with rack positions, pump speed, fuel delivery in cc/1000 strokes and max variation between cylinders in the same units.
    11.8 +/- .1 mm, 1000 rpm, 46.1 +/- 3 cc/1000, 1.5 cc/1000
    10.8, 1900, 43.6 +/-1, 1.0
    6.6, 360, 5.6 +/- 1, 1.0
    12.8 or greater, 100, 29.0-32.0, --
    I think I scanned the book at work and saved the files when I turned in my work computer but I'd have to dig up the disk.
  3. BinderBookie
    Apr 25, 2014
    1,298
    267
    A Farm in Ohio
    Joe- Thanks. Do you have any idea what the "240cc" notation on the plate signifies?
  4. Joe S
    Joe S Farmall Cub
    Oct 27, 2011
    165
    Sunland, Lompoc, CA
    Nope. I'll take a look at mine. I was thinking the total displacement of the pump as you suggested but even then it would have to be for 1000 strokes and it would still be high.
  5. Joe S
    Joe S Farmall Cub
    Oct 27, 2011
    165
    Sunland, Lompoc, CA
    Mine says "Initial Supply Lube Oil", the same in Spanish, (I think) a bunch of chop suey characters and 240 cc on the plate nearest the shaft end so it looks like a drained pump should have that much added before firing it up.
  6. BinderBookie
    Apr 25, 2014
    1,298
    267
    A Farm in Ohio
    That's what I thought. Well, I gotta send the story in and that's a minor detail. Thanks for looking!
