Choke bracket for 800??
Discussion in 'General IH Tech' started by Karen McCrocklin, Apr 15, 2017.
Tags:
  1. Karen McCrocklin
    Karen McCrocklin Farmall Cub
    Apr 7, 2017
    I just bought a 1970 800 in great condition but I noticed the choke was weird. It was pulled all the way out and in order to use it it was a matter of pulling against it at full extension. After looking at it, the bracket that connects the choke cable to the engine/carburetor is missing. The PO used a zip tie to attach the cable to a hose so there is no way to adjust it and it slips when you pull the choke cable..
    I want to buy a new bracket that connects and holds the cable to the engine but I have no idea what it is called or what it looks like. Searching for parts is futile until I know what I'm looking for. Help?
  2. joewatkins
    joewatkins Farmall Cub
    Jan 3, 2017
    336
    42
    Willis Texas
    IMG_20170411_123347.jpg probably doesn't help that my choke was not hooked up in that pic but that's my 68 4cyl 1904 setup
  3. Karen McCrocklin
    Apr 7, 2017
    Great! That helps a lot. Thank you!
  4. jeff campbell
    14,095
    928
    or this style ?
  5. KMcBig
    KMcBig Farmall Cub
    Apr 6, 2017
    This is what it looks like now. You can see where they zip tied the choke cable on to the hose. [​IMG]
  6. jeff campbell
    14,095
    928
    need more pics, take air cleaner off and get some of the other side !
  7. Dana Strong
    4,729
    917
    Which engine/carburetor do you have? Pictures of what's present would help.
    On my 1971 800B with 304 and Holley 2300, the cable ends at a bracket (and associated linkage) which is part of/listed with the carburetor in the parts book.
  8. jeff campbell
    14,095
    928
    looks like a 2210 ?
  9. kevingweq
    kevingweq High Wheeler
    Nov 1, 2013
    2,997
    632
    Sudbury Mass
    Looks like that carby had an electrical choke at some point ,then all the important bits got stripped off
    and the choke cable was run direct :1eye:
  10. Dana Strong
    4,729
    917
    The OP (Karen) hasn't posted a picture yet; the ones in Post #2 & 5 are from other members.
  11. jeff campbell
    14,095
    928
    very observitive
  12. Karen McCrocklin
    Apr 7, 2017
    Ok. Will do
  13. Karen McCrocklin
    Apr 7, 2017
    Ok. Here we go. Here are the pics of the current setup the PO did to the choke cable. I thought it needed the bracket but it is possible this was done for some other reason that I do not understand. All ideas welcome and appreciated.
  14. Karen McCrocklin
    Apr 7, 2017
    The problem is that the choke pull is all the way out and in order to get it to crank I have to yank on the already extended choke pull in the cab. There is not any room for adjustment and it will not go in any further.
  15. Karen McCrocklin
    Apr 7, 2017
    A couple more carb pics
  16. vegestar
    vegestar Binder Driver
    Mar 31, 2006
    855
    56
    Gerlach, NV
    That has to be the worst jurry rig I've seen in a while. Kevin was right a few posts back... that carb used to have an automatic choke. I'm assuming the po stripped those components off when swapping that carb on. If I were you I would be looking for a new/correct carburetor.
  17. Jeff Jamison
    6,915
    634
    All your chock is doing is moving the chock plate,and its missing a lot of parts.You will never get it to work without replacing some pieces.
