my scout hesitates when i step on the gas. looking at the carb i noticed that one of the "squirters" was'nt spraying properly right off idle. what do i need to check? thanks.
Sounds like it's time for a rebuild. There are plenty of threads on here to help you identify and rebuild your carb. Wittmann, eh? I know a guy in the 'burg that might do it, or a couple guys in the valley.
First thing to check is to see if the nozzles on the squirter are clogged up. There is a phillips screw holding the squirter on. Remove it but make sure that you don't loose the black washers that are located between the screw head and squirter and the squirter and the passage. I would place a rag over each barrel so you don't drop the screw and or washers down into the carb. Spray carb cleaner into each nozzle to open up any blockage.
