Carb identification
Discussion in 'General IH Tech' started by danslaw, Jun 30, 2008.
  1. danslaw
    danslaw Farmall Cub
    Provo, UT
    I have a '77 Sout II with a 2 bbl holley carb. Problem is, the PO did an engine swat taking out a 304 and put in a 345. I also have no clue where to find the carb listed on the line setting ticket. So I'm wondering if there is a way to identify the model (whether it is a 2210, 2300, etc. ). Is there a way to identify the carb without pulling it off?
    FYI- I'm not real mechanically inclined, i know enough to ask the right questions most of the time, but don't have a lot of experience.
    Thanks for any responses.
  2. 250gibson
    250gibson Binder Driver
    Aug 17, 2005
    582
    Bucks County, PA
    You can tell just by looking at it. A 2300 will have a float bowl that is attached by 4 screws from the front of the carb. A 2210 is built different, the "top" comes off the carb and that is how you get to the internals. For this reason, 2300s are much eaiser to tune/service.
  3. danslaw
    danslaw Farmall Cub
    Provo, UT
    When you say "top" do you mean the air filter cover?
  4. rlireland
    Sep 8, 2003
    4,473
    Tucson, AZ
    Try this link.
    Roy
  5. 250gibson
    Aug 17, 2005
    582
    Bucks County, PA
    When I say top I mean the air horn. Look on the fuel bowl where it says holley. If it is attached in the corners by 4 screws then it is a 2300.
  6. rlireland
    Sep 8, 2003
    4,473
    Tucson, AZ
    Here's a picture of a Holley 2300.
    Roy
  7. Doc Stewart
    49
    Look at the air horn: The part that sitcks up above the lip that holds the air filter. You will see several numbers stamped into the metal. Write those numbers down and take them to the parts house. They will get the correct kit for you.
  8. M. Mayben
    M. Mayben High Wheeler
    Sep 18, 2002
    2,940
    Leaburg, OR
    For DEFINITIVE IH carb identification go to this link, you will find samples of ALL variations along with additional information.
    The LIST number on the Holley air horn, or main body defines exactly WHICH carb you are concerned with, and what It's OEM application is/was:
    http://www.ihonlynorth.com/forums/carb-tech/
    Any other carb I.D. reference is VERY generic and does NOT include all possible "variations" which "might" have been OEM on IH crap.
    Oops! You must be the same "Dan" that emailed me yesterday??? I see the Utah connection!
