Can this be welded? (Scout 80 door handle part)
Discussion in 'General IH Tech' started by Randall Barringer, Jan 13, 2019.
  1. Randall Barringer
    Mar 4, 2004
    3,721
    854
    baton rouge, louisiana
    To alleviate some door handle sag I am wondering if I can cut off the worn piece of square stock and weld on a new piece.
    I bought a piece of replacement stock that is chrome plated, so I assume I will have to get the plating off if the door handle stock is something that can be welded.
  2. Dana Strong
    5,934
    1,545
    I don't understand how that would solve the problem, but yes, so long as the cut isn't too close to the staked area (which could make the work difficult and allow heat to affect nearby parts). The heating would affect any existing heat-treatment, but I wouldn't think anything more than mild steel would really be needed.
    I see no significant wear; do you mainly mean to lengthen the rod, or are there pits I can't see? If the latter, and greater length isn't needed, the pits could just be filled in and the rod filed or machined square again. Tig would work well for that, but stick (or MIG) could also be used.
    FWIW, if you needed to clean parts further up and change clearances there, the staking could be filed off, parts disassembled, the square rod repaired by welding and filing, and upon reassembly, use a collar epoxied in place, space permitting, instead of re-staking.
  3. Randall Barringer
    Mar 4, 2004
    3,721
    854
    It's worn on the end where it engages with the latch. The latch is square and true.
    I test fit the new piece of stock in the latch and it was nice and tight, no slop.
    Sent from my Moto G Play using Tapatalk
  4. Dana Strong
    5,934
    1,545
    Just building up the end a bit and then making it square again, to fit perfectly, might be easier. It's easy to take a piece of scrap material to practice with, before starting on the good piece.
    David Banner and stroker3 like this.
  5. Randall Barringer
    Mar 4, 2004
    3,721
    854
    Ok.
    That's a good idea.
    Thanks
  6. 70scoutmaster
    70scoutmaster Farmall Cub
    Mar 31, 2010
    32
    Clinton Twp., MI
    I had the same problem and welding the end worked out for me.
    Randall Barringer likes this.
  7. Randall Barringer
    Mar 4, 2004
    3,721
    854
    Thanks!
