Buzzing pcv?
Discussion in 'General IH Tech' started by IH64Scout, Nov 25, 2011.
  1. IH64Scout
    Apr 13, 2004
    4,683
    Jessup,PA
    I noticed after I installed the tbi on my scout I can hear the pcv buzzing like its shaking around. If squeeze the hose it will stop. Does that mean its bad, or did I just not notice it??
    -Jon
  2. Jay Tabor
    Jay Tabor Banned
    Jan 2, 2002
    4,716
    Pahrump, Nevada
    stick your vacuum gauge on hose end..
    we'll wait . . .
  3. IH64Scout
    Apr 13, 2004
    4,683
    Jessup,PA
    well.. i know what i'm doing in the morning... :tt2:
    -Jon
  4. IH64Scout
    Apr 13, 2004
    4,683
    Jessup,PA
    at idle it's dead on 21"hg, high idle it reached 24!
    oh and after i checked i "put" it in gear and moved the wheel chock, guess it just clicked into syncro, rolled across the driveway and hit my terra..... :taz::censored: just glad no one was in the way!
    -Jon
  5. Jay Tabor
    Jay Tabor Banned
    Jan 2, 2002
    4,716
    Pahrump, Nevada
    thats a bummer . .
    I did similar attaching a towstrap to a scout with no steer gear, as i pulled it with another scout, the towed scout swung a huge arc in the yard and headed for my tower scout,
    I got out of the way in time, but it crashed into a 3rd scout in the yard.
    oh well somedays its best to stay inside . . watch tv . .
    as to your buzzing pcv,, with that steady and high suction,
    pull the pcv out a the grommet and stick finger over end, and listen for the buzz .
    should go away...??
    at this point id say the pcv is bad- spring went sproingggggggg
    might have some dirt stuck in the valve,too. swap it with new.
  6. sullyscout77
    sullyscout77 Binder Driver
    Jun 3, 2007
    898
    67
    Conroe, Texas
    Dang Jon! How's the Scout look? :stuart:
    As you said, glad no one was hurt.
  7. IH64Scout
    Apr 13, 2004
    4,683
    Jessup,PA
    The one that hit the terra? The custom rear bumper saved it from any damage....
    -Jon
  8. Comanche Scott
    Comanche Scott High Wheeler
    Aug 28, 2010
    2,419
    250
    Tracy, CA
    OK, so first a Jeep decides to beat you into submission, and yet your resisted!
    Now a Scout goes on a rampage...
    In a "watch-the-train-wreck" sort of way, I'd kind of like to be your neighbor... :D
    Just kidding.
    Hey, if you replace the PCV valve, you might use a later model EFI style one from like a Chevy. It will have a smaller metered orifice with a stiffer spring for the backfire ball.
    One of the cool advantages to EFI, is how much more efficient it is. The high vacuum reading shows this. So the old "drive a Buick, through the metered orifice" type of PCV valve is not really needed.
    But, if you do a lot of short trips (start and stop type stuff), the old style PCV valve will do a better job of keeping the crankcase gasses evacuated. The down side, is you will probably notice a slight increase in oil consumption, as oil vapor, along with crankcase gasses will get drawn through.
