Big six axle swap questions
Discussion in 'General IH Tech' started by mr.blub.blubs142, Apr 12, 2018.
  1. mr.blub.blubs142
    mr.blub.blubs142 Farmall Cub
    Feb 1, 2016
    31
    I have a 64 c1300 dually with big six wheels. I’m looking to ditch them just because I don’t want to have to mess with the lock ring rims. I’ve thought about custom wheels or adapters but due to lack of brake parts available for big six (plus high price for what is available) an axle swap seems like a better deal. I currently can get a killer deal on a complete 74 200 dually truck. My question is whether anyone has swapped newer IH axles into an older IH. Do they fit properly? Anything specific that needs attention? I found plenty about swapping non-IH axles, but with the deal I can get, I’d rather just do newer IH axles
  2. bindermike
    bindermike Farmall Cub
    Apr 6, 2003
    253
    Lorton, VA
    I swapped 71 (or 72, or 73) D-series 2wd single-wheel axles into my '68 1200 pickup. Straight bolt-in swap. I would expect the same for 1300 dually... Brake shoes, wheel cylinders, and hardware is readily available for the D-series axles, but drums are not. I don't know if the 74/75 axles are different than the 69-73 D-series axles. The 200 may be IFS (and disk front brakes), and not a straight axle like your C-series 1300. Good Luck!
  3. mr.blub.blubs142
    Feb 1, 2016
    31
    Straight bolt in swap was what I was hoping to hear! I have a complete 73 driveline as well, though i don’t currently have access to it (its complicated). I haven’t looked at the 74 in person yet so I’m unsure on the front as well. With my truck being 2wd, front isn’t so much a swap issue as rear could be though. I’ll make it work. Thanks!
  4. 46binder
    46binder Binder Driver
    Aug 30, 2009
    619
    Kenosha, Wi
    I had a 72 travelall that was 2wd, and at sometime someone converted it to 4. Unfortunately it was swapped to big 6 closed knuckle. So I would think it would swap backwards.
