Big 6 rim Tube question, which ones?
Discussion in 'General IH Tech' started by BarneyG, Apr 15, 2019.
  1. BarneyG
    BarneyG Farmall Cub
    Sep 4, 2017
    89
    Ellicott City, MD
    Getting some new rubber on the front of my 2wd '67 1200b with the 16" big 6 split lock ring wheels. The current fronts are getting With a bit of searching I found a truck center that will do the work without issue and deal with the lock ring for me, but they are having me source the tire/tube/flaps. They could order them from Coker but I would have to pay their upcharge fee's to have them do it. Guy was nice and told me to do it instead, and not pay them per wheel.
    But having never sourced these before I had no idea what to get for tubes. I know they are 700x16, 5.5 wide, tires (same as on it now), but what tubes do they use? The ones on the truck have 90 degree angle stems so theycome out of the rim.
    Is this what is used?
    https://www.cokertire.com/700-750-15-16-tube-tr440-offset-bent-metal-stem.html
    I guess they bend them on install(?)
    I assume these are the flaps (please advise): https://www.cokertire.com/accessories/tubes/tube-liners/flaps/16-x-7-flap.html
    Thanks.
  2. mallen
    mallen High Wheeler
    2,130
    287
    I just read the description for the tube flaps. It says :
    "This is a 16 x 7 inch flap. A tube liner is an excellent way to extend the life and performance of an inner tube. Tube liners, also known as tube flaps or tube boots and are used to protect tubes from wear, heat, and other irregularities in the rims. Typically used on split rims, two-piece rims or vehicles with wood spoke wheels. These flaps are designed with high quality rubber, made for durability and are available in many sizes. We recommend new tube liners when replacing tires. Speak to a Tire Expert for assistance with your order." And there is a link there. Im honestly NOT trying to be a smartass. Im being totally serious, I didnt notice it was a hyperlink the first time I read it. I'd click that link and ask them what you need.
  3. BarneyG
    BarneyG Farmall Cub
    Sep 4, 2017
    89
    Ellicott City, MD
    LOL, fair enough. Yeah they don't have that link showing with the normal underlining so I didn't notice it either. I'll try it out, I figure I'll get back a less than helpful answer once I tell them it is for a binder. :dig:
    If anyone has gotten them before I'd love to know the stem type, if nothing else it'll be 'on record' in the forums.
  4. BarneyG
    BarneyG Farmall Cub
    Sep 4, 2017
    89
    Ellicott City, MD
    I decided to call Coker instead so I could get a quicker answer. Their guess based on the description I gave (while laying under my truck with a tape) is that I should be using a tube with a TR150 stem, which they don't sell in a 16". Sigh.
    I googled around and found this, which sure seems to like a reasonable fit: https://www.tireinnertube.com/16-in...inner-tube-tr150-stem-for-old-split-rims.html
    I love how the specify "for old split rims". Guess they don't fit "new split rims".
  5. wfdstation42
    wfdstation42 Farmall Cub
    Oct 24, 2012
    29
    St. Pete, Fl
  6. BarneyG
    BarneyG Farmall Cub
    Sep 4, 2017
    89
    Ellicott City, MD
    Thanks, seems like the 440 and 150 are pretty similar to each other. Some of the 440's I see are the metal/brass tubes (without the rubber on the outside) that are pre-bent on a 90. Others say they can be bent with a couple of wrenches.
    Most of the sites say a 150 comes straight and I haven't seen one without rubber on it. The 150 can then be bent by hand to fit. So might be a bit softer or thinner metal in them.
    Guess I'll flip a coin and pick one, seem to be basically the same price at the 16" size. I'll post back after install so the thread will be updated with what I find out.
  7. patrick r
    patrick r Binder Driver
    Aug 23, 2005
    633
    210
    Zionsville, IN
    Give these people a call.
    https://www.universaltire.com/tubes-and-flaps/tubes1016.html
    I don’t remember what mine are but they do have a bent brass stem. I’d prefer the stem be a little longer as they can be hard to fill. I’ll get a measurement off one tomorrow.
    stroker3 likes this.
  8. stroker3
    stroker3 Dreams of Cub Cadets
    Feb 5, 2009
    4,681
    1,830
    Mass.
    It's been years but whenever we needed a tube they had the bent stem and yes, the length matters as well . There was a few times we had to settle and just add stem extenders . Never a problem really but .....
  9. wfdstation42
    Oct 24, 2012
    29
    St. Pete, Fl
    Mine were pre-bent, I would be worried about trying to bend the straight ones without crushing the tube.
  10. Gringo Gomez
    Gringo Gomez Farmall Cub
    May 7, 2015
    93
    35
    Lawrenceville, NJ
    Know that if you have radial tires you must use radial rated tubes and flaps.
    Coker Tire didn’t know there was a difference!
    I used Hanco tubes and flaps inside Firestone Destination A/Ts
  11. BarneyG
    BarneyG Farmall Cub
    Sep 4, 2017
    89
    Ellicott City, MD
    Thanks all. I ordered 2 ply tires and a couple of the 150 tubes and if course flaps. Should all be here by weeks end. Might be able to mount them in Friday if all goes right with shipping. I will update once I get them mounted (or at least try to mount them).
  12. BarneyG
    BarneyG Farmall Cub
    Sep 4, 2017
    89
    Ellicott City, MD
    Wanted to wrap up this thread for 'future generations'.
    Tires are mounted and look pretty good, so I now have two new front tires.
    Got 2 of these tires from Coker: https://www.cokertire.com/tires/brands/tornel/700-16-tornel-lite-truck-6-ply.html and got the offset hole flaps/boots to go with them. They were the cheapest I could find for the look I wanted @ $156 each with $75.59 shipping (ouch). Coker says they are made in the USA, but as far as I know Tornel's are all made outside of Mexico City... Guess I can at least say made in America. :dig:
    I got the TR150 tubes from here: https://www.tireinnertube.com/16-in...inner-tube-tr150-stem-for-old-split-rims.html
    $20 each, free shipping.
    Here is Maryland I found 'Maryland Truck Tires Services Inc' about 10 minutes from my house that mounted them for a bit under $30 each.
    So all in about $530 for the two tires from start to finish. Certainly not ideal, but considering the mileage I put on the truck and the fact the previous set had to be 30 years old I'll never swap them again. And cheaper than new rims + new tires. Luckily the rear tires are fine.
    They did end up putting small brass extenders on the valves to make them clear the rims a bit more, so it would probably be better to stick with the TR440 tubes and have them a bit longer, but the TR150's did work.
    But she's back together and running true... or at least true as she gets!
    Gringo Gomez likes this.
  13. DennyC
    DennyC Farmall Cub
    Jan 7, 2019
    7
    Sorry I missed this thread earlier, but I think I posted elsewhere that if you buy your Coker tires through Summit Racing, you pay the same price as direct from Coker and get free shipping.
    Great info on the tubes. Thanks for the follow-up.
  14. BarneyG
    BarneyG Farmall Cub
    Sep 4, 2017
    89
    Ellicott City, MD
    I saw that thread in my searching (and a really good tip). Unfortunately Summit didn't have the the 700x16's, just 650x16's. Might just be out of them right now. And my old tires were tearing on the insides so they needed to go so I couldn't wait anymore.
    Thanks.
