best i have done so far
Discussion in 'Injection Tech' started by 1967Killer, Aug 29, 2018.
  1. 1967Killer
    1967Killer Farmall Cub
    Jul 31, 2018
    17
    after 6 data logs and quiet a few chip burns , i hope what i have learns here is good enough. A 225 ci mopar 6 with a 350 tbi and a v6 ECM. Its been running good. my chart is below for you to check out and this is the best one so far.
    45.10 49.80 54.90 60.00 61.96 63.92 63.92 70.98 70.98
    45.10 49.80 54.90 60.00 61.96 62.75 65.10 70.98 70.98
    47.06 51.76 47.84 58.04 55.69 72.55 70.20 70.20 74.12
    46.67 48.63 49.02 56.47 57.65 63.53 67.06 75.69 79.61
    45.88 58.82 58.04 58.04 53.33 77.65 72.94 72.94 80.39
    49.80 65.10 58.04 63.53 61.96 63.53 61.57 63.14 80.78
    49.80 71.76 77.25 73.73 65.49 83.53 76.86 85.10 85.88
    49.80 74.51 78.04 81.57 82.75 83.53 86.67 87.06 87.06
  2. Bill USN-1
    16,947
    201
    Too many peaks and valleys.
    You need to manually smooth or use the smoothing option and then log again.
    The table should be evenly spaced throughout.
  3. 1967Killer
    Jul 31, 2018
    17
    I have tried to smooth it best I can. I believe asymmetric fueling is the problem. But it runs better than when I started. The first run was really high and low peaks.
  4. Bill USN-1
    16,947
    201
    IIRC, I specifically said to start with the ASDU bin as shown in the FAQs or you need to disable the asymmetric fueling.
    It will only affect fueling near idle.
    No V6 bin works great on an inline 6.
  5. 1967Killer
    Jul 31, 2018
    17
    Yes sir I know , I just found a 1227747 ECM at the junk yard Wednesday. I will try it soon.
