Battery Recommendation
Discussion in 'Diesel Tech' started by Banjo Bob, Oct 26, 2001.
  1. Banjo Bob
    Banjo Bob Farmall Cub
    Oct 24, 2001
    Bellevue Washington
    I want to buy a new battery for my 1980 SD 33 and was wondering if anyone had a brand/model recommendation with the right crank amps etc.
  2. John Donnelly
    Mar 5, 2001
    13,953
    33
    Woodburn, Oregon
    The right battery
    Bob,
    The correct battery for a Diesel Scout is a "Series 31" Threaded-top style ( there are NO clamp posts, only threaded connections) Battery.
    These are not available at Wal-Mart. NAPA has them in their Commercial series, specialty battery shops, and Most tractor shops have them. This is a VERY heavy-duty battery.
    900 CCA on average, but some are as high as 1150 CCA.
    The nice thing about a series 31 battery is, it has heavy duty plates, is resistant to vibration, and they last for YEARS. How does 5 to 10 YEARS grab you?
    My 1980 Turbo-Diesel Scout had it's original Series 31 battery for 12 years before it died. I have the original owners documentation to prove it. It is still only on it's second battery and that one is working just fine.
    Get a Series 31, pay the 70 to 100 bucks, and be happy, for a long time.
    Keep on Dieselin',
    John Donnelly
  3. Dave L
    Dave L Farmall Cub
    183
    Stansbury Park, Utah
    Could this series 31 battery be used, on a gas engine? I was using an Optima Red Top. The Deep cycles (Yellow) run like $190. $70- $100 sounds alot better fro that much power and length of use.
  4. John Donnelly
    Mar 5, 2001
    13,953
    33
    Woodburn, Oregon
    battery for a gasser
    Dave,
    Absolutely! As long as your battery box will hold it. I have seen gasser Scouts with non-recessed battery box locations.
    I see no reason why you couldn't use a Series 31.
    All MY Scouts have Series 31, but then again all of mine are Diesels :D .
    In all seriousness, you should be able to use it with no worries. And the power available is something that those power hungry things like winches just LOVE.
    Keep on Dieselin',
    John Donnelly
