backwards hood
Discussion in 'General IH Tech' started by Sammy, Feb 19, 2020.
  1. Sammy
    Sammy Y-Block King
    Oct 22, 2001
    3,155
    449
    Grigsby's Bluff, TX
    I don't like the way that IH hinged the hood on the Scout II, it's backwards. It's not fast or have any other reason to have the hood mounted backwards. Makes it a pita when doing anything under the front. I have a catch that consists of hood pins. What I'm looking for is hood hinges to lift the hood. Not really concerned how but not doing a jeep method of a fence hinge with holes in the hood. I know I'm not the only one, so who else has done it and what did you use? TIA
  2. fodman
    fodman Farmall Cub
    Nov 16, 2019
    :saddam: uh..... it would be backwards if it hinged at rear of hood.
    Erik Morton likes this.
  3. Afireinside2285
    Afireinside2285 High Wheeler
    Nov 2, 2003
    1,768
    colorado
    The reverse hood on a scout is awesome, actually makes working on things much easier.
    I have removed several radiators by sliding the prop out. Cant see any reason it is bad. Plus I like the way it looks
    Greg R, winchested and scout2000 like this.
  4. MrKenmore
    MrKenmore Dreams of Cub Cadets
    4,240
    1,832
    If the Scout II hood hinged at the back I wouldn't be able to open it in my tiny garage (staircase in the way)!
    jeff campbell and stroker3 like this.
  5. stevewillis
    stevewillis Farmall Cub
    Jul 24, 2006
    388
    109
    Flagstaff, AZ
    Federal Motor Vehicle Safety Standard (FMVSS) 113 requires a front opening hood to have a more complicated latching mechanism with a second position, or a redundant second latch. This is why you have to feel around for the lever after releasing the hood in modern vehicles. I think that standard applied from 1968 onward. Just speculating, but reversing the hinge for the Scout II might have saved some coin. Or, maybe International was just anticipating that MrKenmore would want to park under his stairs.
    Blaine Man, kdsmit and oneof3k like this.
  6. winchested
    winchested Dreams of Cub Cadets
    4,227
    1,709
    I love my corvette hood on my SII! You can pull the lock arm out and fold it more backward.
  7. stroker3
    Feb 5, 2009
    5,978
    2,986
    Mass.
    You mean forward......:laugh:
    You're right . Much better to say Corvette or T'bird hood because saying it's Vega or a 80's Buick Park Ave hood just doesn't cut it for some reason....:dig:
    oneof3k likes this.
  8. oneof3k
    oneof3k High Wheeler
    May 24, 2017
    1,680
    1,597
    Never had a vette or Tbird, but I've owned several reverse-hooded Saabs! Whether done for a style statement, cost savings, or just to be different, it's a horrific first world problem, for sure.
  9. jeff campbell
    15,956
    1,784
    Never have to worry bout it flying up an busting windscreen
    vince konicki and stroker3 like this.
  10. Greg R
    5,194
    807
    Quote of the year!! And I certainly am willing to believe it. ;)
  11. Don B
    Don B Binder Driver
    Dec 23, 2018
    889
    315
    Hell of a lot of Scout 80 and 800’s with bent backwards creased hoods that I’ve seen. Mine was like that and lots more so the Scout II hood makes a lot of sense. Looks cool too!
    If you do have an early Scout consider putting in a safety chain or something to prevent your hood flying up and folding with all the fun that will entail!
    Don B
    Bryan Johnson and jeff campbell like this.
  12. jeff campbell
    15,956
    1,784
    I have 2 like that.bent hoods
  13. Don B
    Don B Binder Driver
    Dec 23, 2018
    889
    315
    Great spray paint test panels!
  14. Erik Morton
    Erik Morton High Wheeler
    Jan 19, 2006
    2,128
    1,210
    Denton, MD
    That works well until you want to put the hood back down. I am guessing you use a stick to release the pin holding it up. I have a cable to the driver's side to do that.
  15. 1975IH200
    1975IH200 Y-Block King
    3,394
    631
    Don't forget, the Edsel had the same style hood.
    stroker3 and jeff campbell like this.
  16. Darrel
    4,999
    1,160
    I've seen many dream about it, but that usually as far as it goes. The heater box is smack dab where the passenger hinge would need to go and the hood isn't set up for hinge bolts nor is it reinforced for the leverage of being forced down against hinge springs. Then up front you would need to add a safety latch and release handle. Going to a full on tilt hood (edit: meant to say tilt front end) isn't much if any more difficult. Still not worth it imo. If I'm doing a lot of work up front like a water pump job it only takes 3 minutes to pull the hood off.
    jeff campbell and vince konicki like this.
  17. Bryan Johnson
    Bryan Johnson Farmall Cub
    May 28, 2018
    210
    284
    Fairbanks, Alaska
    Thats how the hood on my 80 is, all bent up, and theres a spot on the windshield frame where the loop on the hood imbedded itself
    oneof3k likes this.
  18. MrKenmore
    4,240
    1,832
    You are right on the money. I have a perfectly cut 2X4.
  19. Erik Morton
    Jan 19, 2006
    2,128
    1,210
    Denton, MD
    2 x 4's are remarkable solutions to a lot of problems!
    TorqueMonster1 likes this.
  20. Patrick Morris
    6,309
    944
    Gonna say, Saabs and older bmw cars had the same kind of hood configuration.
    Additionally, I consider it a theft deterrent. The average thief would probably fumble around behind the grill with their fingers and then just give up. Meanwhile the actual hood release can be tucked in behind the dash. Nothing but a mysterious hole there.
