Are my ring and pinion bad???
Discussion in 'General IH Tech' started by ScottTX, Feb 16, 2020.
  1. ScottTX
    ScottTX Farmall Cub
    Feb 2, 2017
    255
    79
    Like all my projects, this started as a drum brake pad check. Now I am wondering if I need a new ring and pinion. Check out these pics and let me know your thoughts. I have never broken into the diff before, so I don't know if this is normal or not. It just doesn't fell right. There is pitting on the ring and grooves on the edges of the worm gears. I plan to do a contact test, but I need to get some marking paint. Any help is appreciated!
    [​IMG] [​IMG] [​IMG]
    [​IMG] [​IMG]
  2. Greg R
    Greg R Dreams of Cub Cadets
    4,974
    665
    What does not feel right? Do you know the backlash?
    Going on the pictures, I'd check for cleanliness, lube them up good; and run them.
    vince konicki and ScottTX like this.
  3. jeff campbell
    15,009
    1,348
    Run it.if no chunks missing our of teeth then use it.
  4. winchested
    3,049
    1,084
    I dont think it's terrible. There was obviously water in it for some time in its past life.
    If it doesn't scream when driving it leave it.
    However id pull the axles and then the carrier to inspect all the bearings for pitting.
    ScottTX likes this.
  5. ScottTX
    ScottTX Farmall Cub
    Feb 2, 2017
    255
    79
    Damn you guys are fast! It's not causing me noise or issues. I pulled the axles to change the bearings (SET10 and 9211 seal) and decided to change the gear oil while the whole thing was apart. That is when I saw the pitting. The backlash is .012, which I think is out of spec but I need to check it again. I like the advice to pull the carrier to look at the bearings while I in here.
  6. jeff campbell
    15,009
    1,348
    Shove axles back in an go. Not th a t bad
    ScottTX and vince konicki like this.
  7. mallen
    mallen Y-Block King
    3,024
    632
    If it doesn't make noise and it doesn't get hot, I would not worry
    ScottTX likes this.
  8. mongocanfly
    mongocanfly High Wheeler
    Nov 5, 2017
    1,448
    981
    Alabama
    I agree..run it...
    ScottTX likes this.
  9. Greg R
    4,974
    665
    [QUOTE ]The backlash is .012, which I think is out of spec [/QUOTE]
    No, .012" is good, real good for a used set. No noise, no chunks, no heat is all good.
    ScottTX and jeff campbell like this.
  10. ScottTX
    ScottTX Farmall Cub
    Feb 2, 2017
    255
    79
    Thanks gents...never seen a thread where everyone agrees! Time to clean everything up and slap it back together.
    winchested likes this.
  11. Jeff Ismail
    Jeff Ismail High Wheeler
    Apr 8, 2003
    1,660
    145
    Grass Valley, CA
    If that ring and pinion came thru my shop I would change it as I would not be able to stand behind a gear set that looked like that. Besides the rust it does have a funky pattern to it. Since you're not rebuilding, and were merely just servicing it, I'll agree with the others and just run it until it wears itself out.
  12. ScottTX
    ScottTX Farmall Cub
    Feb 2, 2017
    255
    79
    Oh well...guess I need new carrier bearings. Glad I pulled it.
