Anyone Know What Was Written on My 1310 Frame?
Discussion in 'General IH Tech' started by Chris Cooper, Feb 11, 2019 at 11:15 AM.
  1. Chris Cooper
    Chris Cooper Farmall Cub
    Mar 11, 2018
    135
    17
    I’m guessing it might be a warning about welding the frame, but I can’t tell:
  2. DT466
    DT466 Farmall Cub
    Nov 20, 2010
    319
    46
    Wichita, KS
    That looks like 'frame flange'. Is there more before it?
    Dean
  3. clemk
    clemk Farmall Cub
    Oct 28, 2015
    I'm with Dean. What I can see looks like frame flange, but I'm sure I see more in front of it
  4. Howard Pletcher
    Howard Pletcher Farmall Cub
    Jul 23, 2007
    235
    73
    Fort Wayne, IN
    I believe it was a warning about not welding on the frame flange
  5. RinTX
    1,373
    266
  6. stroker3
    stroker3 Dreams of Cub Cadets
    Feb 5, 2009
    4,472
    1,702
    Mass.
    Know very little about proper welding procedures or frame work but do recall warnings like that on frame rails about drilling and/or welding.
    Found this with a search.....
    Frame Repair and Reinforcement: General Rules Specific frame repair and reinforcement procedures vary depending on circumstances and materials. The general guidelines outlined here, however, are very important and apply to virtually all repair and reinforcement situations. • Always identify the material that makes up the base rail. Reinforcement should be of the same or better material than the base rail. • Make sure that only fully trained, qualified specialists perform frame straightening and other repairs. • Always try to identify the cause of the failure. • Do not attach fifth wheels or body and accessory mountings through frame flanges. Refer to GM Body Builders Manual for additional information. • Do not drill holes in top or lower flanges. • Use only proper electrodes as specified for base rail material when welding is necessary. • Do not use oxyacetylene welding equipment on frames. • Do not weld reinforcements across the frame flanges. • Do not weld within 19 mm (0.75 in.) of the edge of a frame flange.
  7. Chris Cooper
    Mar 11, 2018
    135
    17
    Too late for that: that frame has full-height plates welded to it from underneath the cab to just forward of the rear spring pivot. The quality of cuts on those plates tell me this was done at the McCabe-Powers shop where this truck was modified into a utility or bucket truck. The chicken-poop welds say otherwise though, like it was done by its later fire-zone owner.
    Big Ed likes this.
  8. Chris Cooper
    Mar 11, 2018
    135
    17
    I imagine there used to be, but rust has made it impossible to tell.
  9. jeff campbell
    13,131
    651
    Because of old school law " don't weld vertically on a frame, only horizontally.
    stroker3 likes this.
  10. stroker3
    Feb 5, 2009
    4,472
    1,702
    Mass.
    From what you see done to frames , kinda figured it was a mfg CYA thing.
  11. Darrel
    Darrel Y-Block King
    3,727
    545
    There's not much extra strength designed into many c-channel frames so if the flange(s) is compromised it can fold up. Just like an I-beam the flanges are a large part of it's strength.
    There are similar warnings in the light line manuals.
  12. mallen
    mallen High Wheeler
    1,770
    183
    In the service manual in the section on frames there are very specific guidelines for welding the frame. The frames on most IH trucks are made out of heat treated steel. As such,heating them can destroy the temper of the metal. One of the rules is to use only arc welder (SMAW, MIG,TIG), but never use oxyfuel welding. There are additional guidelines for frame repair such replacement sections in by cutting at a 45 degree angle and reinforce them with channel stock, plug welded in place. I imagine you would rarely if ever want to simply weld something to the frame. It creates a weak spot on the frame that could fail under load. (My strategy to attach things to the frame has always been to find existing holes and make a bracket, bolted in place with grade 8 hardware.)
    Chris Cooper likes this.
  13. mallen
    mallen High Wheeler
    1,770
    183
  14. tigwelder
    tigwelder Farmall Cub
    Nov 19, 2012
    90
    maple
    i have same thing on frame of my 51 L-120 panel truck.
  15. DeepSoutBulldawg
    DeepSoutBulldawg Farmall Cub
    Jul 31, 2018
    35
    “DO NOT CLEAN!”
